What determines the coefficient of friction?
The discussion centers on the factors that determine the coefficient of friction, exploring the influence of material properties, surface conditions, and specific examples. Participants examine both theoretical and practical aspects of friction in various contexts.
  • Some participants propose that the coefficient of friction depends on the materials involved and their surface conditions.
  • One participant provides specific examples of coefficients for copper surfaces under different conditions, highlighting the variability due to surface impurities.
  • Another participant questions the implications of coefficients greater than unity, suggesting that this indicates a greater force required to slide an object compared to lifting it.
  • There is a discussion about the plausibility of moving rubber on rubber through the air being less work than sliding it, indicating differing views on practical applications of friction coefficients.
  • A participant references R. Feynman's explanation regarding the bonding of pure substances and how impurities affect friction, illustrating the complexity of the coefficient's dependence on various factors.
  • The concept of local bonding or fusion between surfaces is introduced as a factor in friction, along with surface roughness and mechanical interlock.
  • Another participant mentions the role of lubricants in reducing friction by minimizing interlock, and introduces the field of Tribology as relevant to the discussion.
Participants express multiple competing views regarding the factors influencing the coefficient of friction, and the discussion remains unresolved with no consensus reached.
Participants note the influence of surface impurities and roughness on friction, but do not fully resolve how these factors interact or the implications for different material combinations.
jhk0428
I don't understand what determines the coefficient of friction. Can someone explain it to me using examples?
What the coefficients of friction depend on are the materials the object and the surface it's sliding over are made of.
The coefficient depends on the two materials and especially on the impurities on their surfaces. For example take copper and copper. "Clean and dry" 1.21. Thick oxide film .76. Sulfide film .74. These values serve to illustrate how variable the coefficient can be. If you cleaned the copper perfectly and stuck the two surfaces together in a vacuum, you would get a huge coefficient because essentially the two pieces fuse together into one continuous copper piece.
Vargo, it would be worth expanding upon coefficients greater than unity since this implies a greater force required to slide the object than to simply lift it off the other surface and move it along, supporting it in thin air.
Good point Studiot. But consider rubber on rubber. Doesn't it seem plausible that picking up the rubber and moving it through the air would be less work? Check out
http://www.engineershandbook.com/Tables/frictioncoefficients.htm for other particular examples.
I don't know a lot about this personally, but I can try to faithfully paraphrase R. Feynman in "Lectures on Physics". If you have two surfaces of the same pure substance such as copper and you are somehow able to eliminate all impurities separating them, then they can bond together and form a continuous metal piece. Apparently this can be observed at home with glass on glass. If you put a bit of water between the surfaces it can lift the impurities out of the way and allow the two pieces of glass to bond together in places. If you then slide one along the other, you will notice nicks in the glass where the two pieces of glass were ripped apart.
I don't know how this phenomenon would affect the coefficient of friction between two different materials like copper and steel, but it at least serves to illustrate the tricky nature of the coefficient and its dependence on "hidden variables" such as surface impurities that could vary depending on the exact situation.
Pity because I thought I was offering you a cue.
:smile:
Local bonding or fusion between the two surfaces is one aspect of friction.
Another is the degree of surface roughness, which allows some mechanical interlock to increase friction.
Reducing such interlock is also the main part of the mechanism of lubricants in reducing friction.
The science of surface contacts is known as Tribology.
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 71 ·
12K
