Solving Motion along a Line: Finding Turning Points, Max U & Frequency
  • Thread starter Thread starter zebrastripes
    Line Motion
The discussion focuses on analyzing the motion of a particle P of unit mass along the x-axis under the force F(x) = 2(x³ - x). The potential energy is defined as V(x) = x² - x⁴/2, with equilibrium points at x = 0 and x = ±1. The participant seeks to determine the turning points as a function of initial speed U and the maximum U for bounded motion, as well as to prove that small displacements from x = 0 lead to periodic oscillations with a frequency of √2.
  • Understanding of Newton's second law
  • Familiarity with conservation of energy principles
  • Knowledge of potential energy functions
  • Basic concepts of harmonic motion
  • Learn how to derive turning points from energy conservation equations
  • Study the characteristics of simple harmonic motion
  • Explore the implications of small angle approximations in oscillatory systems
  • Investigate the stability of equilibrium points in potential energy graphs
Students studying classical mechanics, particularly those focusing on dynamics and oscillatory motion, as well as educators looking for examples of energy conservation and harmonic oscillators.
zebrastripes
A particle P of unit mass moves along an x-axis under the influence of the force
F(x)=2(x[itex]^{3}[/itex]-x)
Firstly, I find V(x)=x[itex]^{2}[/itex]-x[itex]^{4}[/itex]/2.
Where equilibrium points are F(x)=0 so x=0 with energy V(0)=0, x=1 with energy V(1)=V(-1)=1/2.
And I have also sketched the graph.
So here are the parts I'm stuck on:
1) Initially P is projected from the point x=1/2 with speed U. Using conservation of energy, find the turning points (where x'=0) as a function of U. Find the maximum value of U for which the resultant motion will be bounded.
2)Stating from Newton's second law, prove that a particle displaced by a small amount from x=0 will perform periodic oscillations with a frequency of [itex]\sqrt{2}[/itex]
T=mx'[itex]^{2}[/itex]/2
T+V=E
So for 1), I start with
U[itex]^{2}[/itex]/2+(1/2)[itex]^{2}[/itex]-(1/2)[itex]^{4}[/itex]/2=E
Giving E=U[itex]^{2}[/itex]+7/16
Then, because energy is conserved and x'=0 at turning points:
x[itex]^{2}[/itex]-x[itex]^{4}[/itex]/2=U[itex]^{2}[/itex]+7/16
And now I'm really stuck for how to find the turning points as functions of U?
I'm guessing I'm going about this the completely wrong way??
And I have no idea what I'm supposed to be doing for 2) :frown:
Sorry this is long, but any help will be greatly appreciated :smile:
T+V=E
If v = velocity (= dx/dt), then by conservation of energy we have
[tex]\frac{1}{2} v^2 + V(x) = \frac{1}{2} U^2 + V(1/2) = <br /> \frac{1}{2} U^2 + \frac{7}{32},[/tex] since [itex]V(1/2) = 7/32.[/itex] At turning points, [itex]v = 0,[/itex] so you get an equation in [itex]x.[/itex]
For small |x| the potential V(x) is almost linear in x. If you neglect the x4 term in V(x) you get a simple harmonic oscillator.
RGV
RGV
Thanks RGV, but under what assumptions can I say for small |x|?
And would you mind giving me a hint about what to do for part 2)?
Thanks again!
  • · Replies 19 ·
