Understanding the Lagrangian Density Dependence on Field Variables
The discussion centers around the dependence of Lagrangian density on field variables and their derivatives, particularly in the context of field theories such as the Klein-Gordon Field Theory. Participants explore the implications of assuming that Lagrangian density depends only on first-order derivatives and the consequences of allowing higher-order derivatives.
  • One participant questions the assumption that Lagrangian density only depends on field variables and their first derivatives, referencing Ashok Das's Lectures on Quantum Field Theory.
  • Another participant explains that the Euler-Lagrange equation for Lagrangians with at most first-order derivatives leads to equations of motion that are second-order in time derivatives, using the classical Newtonian point-particle Lagrangian as an example.
  • A different viewpoint suggests that while higher-order derivatives can be included in Lagrangians, doing so may lead to complications in quantum theories, such as issues with the Hamiltonian not being bounded from below.
  • One participant interprets the original author's confusion as a dismissal of the need for deeper explanation regarding the assumptions made about derivative orders in Lagrangian density.
Participants express differing views on the implications of including higher-order derivatives in Lagrangian density. There is no consensus on the necessity or implications of restricting to first-order derivatives, as some argue for the flexibility of including higher orders while others caution against it.
There are unresolved assumptions regarding the implications of higher-order derivatives in Lagrangian density and their effects on the physical validity of the resulting theories. The discussion reflects a range of perspectives on the foundational principles of field theory.
bigbigtheory
Hi, guys,
Why do we assume Lagrangian Density only depend on field variables and their first derivative?
Currently, I am reading Ashok Das's Lectures on Quantum Field Theory.
He says (when he is talking about Klein-Gordon Field Theory):
"In general, of course, a Lagrangian density can depend on higher
order derivatives. However, for equations which are at most second
order in the derivatives, the Lagrangian density can depend at the
most on the first order derivatives of the field variables. These are
the kinds of equations we will be interested in and correspondingly
we will assume this dependence of the Lagrangian density on the
field variables through out."
I am a bit confused about what he says.
If you look at the Euler-Lagrange equation for Lagrangians with at most, 1st order derivatives, you'll see that you can only get 2nd order derivatives out as your equations of motions. For example, if you have the classical Newtonian point-particle lagrangian
[itex]L = \frac{1}{2}{\dot {\vec{x}}}^2 + V(\vec{x})[/itex]
you have a Lagrangian that depends only on the position and first-time derivative of the position. The Euler-Lagrange equations of a Lagrangian with at most, first-time derivatives will only introduce 1 more order of time derivatives. What comes out, of course, is the equations of motion as Newton's 2nd law, [itex]\nabla {V(\vec{r})} = m{\ddot{\vec{x}}}[/itex] which is 2nd order in time derivatives.
You can construct Lagrangians with 2nd or higher-order time derivatives and the Euler Lagrange equations will produce equations of even higher-order time derivatives. As they said, you can move beyond Lagrangians with first-order derivatives, but you want to start at first-order. When you setup the Klein-Gordon field, you're essentially doing the same thing, except with space-time coordinates of a field instead of simply time and you're now dealing with a density (since they're fields) instead of a point-particle model.
Don't worry about not understanding what he says. He's basically saying "I feel like it's a waste of time to explain why."
One thing you might consider is that the energy relation is: p^2/2m, or sqrt[p^2+m^2], and noting that momentum is the derivative, so your equation will have 1st or 2nd derivatives in the fields, since:
d/dt[wave function]=H[wave function]
where H is the Hamiltonian.
For field theories, you can assume whatever order of the derivatives you want, even infinite (so-called non local theories), it's that the na:ive quantum theory of those fields makes no sense (hamiltonian not bounded from below), that's why the field equations must be second order the most.
  • · Replies 23 ·
