Evaluate surface integral over surface
The discussion focuses on evaluating the surface integral of the function G(x,y,z) = 6x over the parabolic cylinder defined by y = 2x², with bounds 0 ≤ x ≤ 5 and 0 ≤ z ≤ 5. The solution involves using the gradient of the function f(x,y,z) = y - 2x² to find the normal vector and subsequently calculating the double integral of G.n/n.n* over the surface S. The final result is derived through parameterization of the surface, leading to the integral ∫∫ G dS, which is crucial for determining the correct answer from the provided options.
  • Understanding of surface integrals in multivariable calculus
  • Familiarity with vector calculus concepts, including gradients and normal vectors
  • Knowledge of parameterization techniques for surfaces
  • Proficiency in evaluating double integrals
  • Study the method of parameterizing surfaces in three-dimensional space
  • Learn about the gradient and its application in finding normal vectors
  • Explore the differences between scalar and vector surface integrals
  • Practice evaluating double integrals over various surfaces
Students and professionals in mathematics, physics, and engineering who are working with surface integrals and vector calculus, particularly those preparing for exams or tackling complex integration problems.
ride4life
Evaluate the surface integral of G over the surface S
S is the parabolic cylinder y=2x^2, 0=< x =<5, 0=< z =<5
G(x,y,z)=6x
Answer is one of the following:
1. (15/8)*(401sqrt(401)-1)
2. (5/8)*(401sqrt(401)-1)
3. (15/8)*(401sqrt(401)+1)
4. (5/8)*(401sqrt(401)+1)
Let f(x,y,z)=y-2x^2=0
n=gradf/||gradf||=(-4xi+1j+0k)/sqrt(16x^2+1)
n*=j
G.n=-24x^2/sqrt(16x^2+1)
n.n*=1/sqrt(16x^2+1)
therefore the double integral over S = SS (G.n/n.n*) dzdx
solving the double integral gets -5000
Let me try ot reason through what you have. If at the end you were integrating dzdx, I'll assume I should try to paramet(e)rize the surface in x and z.
Then r(x,z)=(x,2x^2,z). Then r_x=(1,4x,0), while r_z=(0,0,1).
Then cross product is (r_x)x(r_z)=(4x,-1,0).
Then the infinitesimal area on the surface is given by
dS=sqrt(16x^2+1)dxdz.
Now we want to integrate the SCALAR G(x,y,z)=4x against the area.
That is, integrate G dS.
So [itex]\int_{x=0}^5\int_{z=0}^54x\sqrt{16x^2+1}\ dzdx.[/itex]
So my first guess is, you are mixing up VECTOR integrals with SCALAR integrals. You might compare them and their derivations.
  • · Replies 105 ·
13K
