Prove cos(sin^-1 x)= [itex]\sqrt{1-x}[/itex]
  • Thread starter Thread starter nowayjose
The discussion revolves around proving the identity cos(sin-1x) = √(1 - x2), focusing on trigonometric identities and relationships between sine and cosine functions.
  • Participants suggest using a right triangle to relate the sine and cosine of an angle defined by the inverse sine function. There are discussions about the implications of the triangle's sides and the application of the Pythagorean theorem.
The conversation includes various interpretations of the problem, with some participants providing insights into the relationship between sine and cosine. There is acknowledgment of misunderstandings regarding notation and the properties of inverse functions, but no explicit consensus has been reached.
Some participants express confusion over the notation used, particularly regarding the inverse sine function and its implications. There are also mentions of potential typos and clarity issues in the original posts.
nowayjose
cos(sin-1x) = [itex]\sqrt{1-x^2}[/itex]
I would assume trigonometrical identities would be used to prove this.
Hello nowayjose! :smile:
Yes, they would...
Why don't you start by assuming [itex]\theta = sin^{-1}x[/itex], and then draw out a triangle to find a relation between theta and cosine, that you can use...
PS : your thread title is misleading :rolleyes:
Thanks for the prompt reply!
Sorry, and the question's undoubtedly stupid. I've used this method before and haven't happened to used any identities (or so i believe...).
[itex]sin\theta = x[/itex]
[itex]sin = 1/X[/itex]
the cosine side must therefore be [itex]\sqrt{1-x^2}[/itex]
therefore the cosine angle is
[itex]\sqrt{1-x^2} / 1[/itex]
Or, different wording of the same idea: [itex]sin^2(\theta)+ cos^2(\theta)= 1[/itex] so that [itex]cos(\theta)= \pm\sqrt{1- sin^2(\theta)}[/itex]. So
[tex]cos(sin^{-1}(x))= \pm\sqrt{1- sin^2(sin^{-1}(x)}= \pm\sqrt{1- x^2}[/tex]
nowayjose said:
Thanks for the prompt reply!Sorry, and the question's undoubtedly stupid. I've used this method before and haven't happened to used any identities (or so i believe...).
What you have written here makes little sense. If [itex]\theta= sin^{-1}(x)[/itex] then, yes, [itex]sin(\theta)= x[/itex], but you cannot write "sin" without some argument. And the "-1" does NOT indicate reciprocal (1/x), it means the inverse function.
consider the attached triangle picture (sorry its sloppy)
in that case Sin(theta) = x (hypotenuse is 1, opposite is x)
thus sin^-1(x) = theta.
For that same theta, using a^2 + b^2 = c^2...
x^2 + b^2 = 1^2
b^2 = 1-x^2
b = sqrt( 1 - x^2)
and cos(theta) = adj / hyp
so,
cos(theta) = sqrt( 1 - x^2) / 1
recall:
sin^-1(x) = theta
so sub in theta
cos(sin^-1(x)) = sqrt( 1 - x^2)
Proved!
People sorry for the typo and for not being clear about my thought process.
Bascially what i meant was:
If the sine angle is X, then the opposite is X and the hypotenuse 1.
the adjacent side can now be calculated using pythagoras, which gives [itex]\sqrt{1-x^2}[/itex]
The cosine angle is the quotient of the adjacent and the hypotenuse:
Would you care explaining me how you multiplied out what's rooted?
I know sin(sin^-1) cancel out because you add the indices, so shouldn't that leave sin x..
Those are inverse functions, so they don't simplify like exponents do.
Since sinx and sin-1x are inverses and sin2x = (sinx)2, sin(sin-1x) = x and
sin2(sin-1x) = (sin(sin-1x))2 = x2
No, don't think of it that way. Inverse functions are a fancy word of saying "doing the opposite". You have some function, such as [itex]y=\sin(x)[/itex] and you want to make a process to get back to just x, and for this case its inverse will be [itex]\sin^{-1}(y)[/itex].
Other inverses are, for example, the inverse of [itex]y=x^2[/itex] is [itex]\sqrt{y}[/itex] because [itex]\sqrt{x^2}=x[/itex] (technically it's |x| so that's why we specify domains, in this case [itex]x\geq 0[/itex])
Another would include [itex]y=\ln(x)[/itex] and [itex]e^y[/itex]
Also, keep in mind that if you have a function [itex]y=x^n[/itex] and applying its inverse [tex]\sqrt[n]{y}=y^{1/n}[/tex] the reason we get back to x is because [tex]\left(x^n\right)^{1/n}=x^{n\cdot\frac{1}{n}}=x^{\frac{n}{n}}=x[/tex]
You multiply the indices, not add.
  • · Replies 23 ·
