Question about the Two-Body systems
  • Context: Undergrad
  • Thread starter Thread starter Ronel
    Systems
The discussion focuses on calculating the acceleration of two blocks connected by a rope under the influence of an applied force and friction. Given an applied force of 55 N and a frictional force of 44.1 N, the net force is determined to be 10.9 N, resulting in an acceleration of 0.363 m/s² for the combined mass of 30 kg. Additionally, the friction on the 10 kg block is specified as 14.7 N, leading to a query about calculating the tension in the connecting rope without knowing the friction of the 10 kg block. The solution emphasizes the use of ratios for frictional and accelerational forces to derive the tension.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of frictional force calculations (Ff=μFn)
  • Basic algebra for solving equations
  • Familiarity with tension in connected systems
  • Study the concept of tension in multi-body systems
  • Learn about calculating friction coefficients in various materials
  • Explore advanced applications of Newton's laws in dynamics
  • Investigate the effects of varying mass on acceleration in connected systems
Students and educators in physics, mechanical engineers, and anyone interested in understanding dynamics in two-body systems and the principles of force and motion.
Ronel
Two blocks of identical material are connected by a light rope on a level surface. An applied force of 55N
causes the blocks to accelerate. While in motion, the magnitude of the force friction on the block is 44.1 N. Calculate the acceleration of the blocks.
20 kg|---------------------10kg | -----------------
(sorry about the diagram it looks ugly)
Fnet= Fapp - Ff
Fnet= 55 N - 44.1
Fnet= 10.9N
Fnet=ma
a=Fnet/mt
a=10.9 N/30 kg which is equal to .363
Here's another question: Refer to the information above. The force on friction on the 10-kg block has a magnitude of 14.7 N.
a) calculate the tension in the rope connecting the two blocks
My solution
Ff= μ Fn
μ= Ff/Fn
μ= 44.1/196.2
μ= .2247
I know how to get the Ff2 this is what I did -----> Total Friction(44.1) - 14.7(Ff1 =Friction of 10Kg) = Ff2= 29.2 (20Kg)
My question is can you still answer the a) question without knowing the Friction of 10kg ? (Ff1) I got question a right but just wondering if you can still answer it without know the Friction of 10kg (Ff1).
I don't see where you arrive at the tension.
The easiest way is to think about the following ratios:
- frictional force, blk1 v. blk2 v. combined
- accelerational force, blk1 v. blk2 v. combined
- tension in RH rope v. tension in LH rope
