The product of 8 consecutive natural numbers will not be a perfect square?
The discussion revolves around the question of whether the product of 9 consecutive natural numbers, represented as n(n+1)(n+2)...(n+8), can be a perfect square. Participants explore various approaches and reasoning related to this problem, including factorials and prime factorization, while also addressing some confusion regarding the initial problem statement.
  • One participant wishes to show that the product of 9 consecutive natural numbers is not a perfect square, referencing a related problem involving factorials.
  • Another participant points out a discrepancy in the initial post regarding the product and sum of numbers, asking for clarification on the intended case.
  • Some participants discuss Bertrand's postulate as a means to support their arguments about the presence of primes in the range of numbers considered.
  • One participant proposes a proof by contradiction, suggesting that if the product were a perfect square, the prime factors would need to be in even powers, which leads to a contradiction due to the existence of a largest prime.
  • Another participant challenges the logic of the proof, questioning its validity and providing a counterexample involving specific numbers.
  • Further attempts to refine the proof are made, with participants discussing the maximum number of times each prime can divide the product and the implications for the evenness of their exponents.
Participants express differing views on the validity of proposed proofs and reasoning. There is no consensus on whether the product of 9 consecutive natural numbers can be a perfect square, and the discussion remains unresolved with multiple competing ideas presented.
Participants note limitations in their reasoning, including assumptions about prime factors and the conditions under which their arguments hold. Some mathematical steps and definitions remain unresolved, contributing to the ongoing debate.
iceblits
I wish to show that the sum of 9 consecutive natural numbers: n(n+1)(n+2)(n+3)...(n+8) will not be a perfect square.
This problem came by as a result of another problem I was doing and I'm wondering if anyone knows/has come across this already.
After some searching I found that n! is not a perfect square (although I found no proof).
In my case I wish to show that (n+8)!-(n-1)! is not a perfect square.
Your title says product of 8, your opening text says sum of 9, which you then illustrate with a product of nine. And you finish with an expression which is the difference of two factorials (I guess you meant the ratio?). Please clarify which case you're interested in.
As for n! never being a square, can you show that there is always a prime between n and n2?
Oh sorry about the confusion...i meant consecutive 9.. as for the difference I think it is correct...the main problem is to show n(n+1)..(n+8) is not a perfect square...
As for n!..i did a bit more searching and found bertrands postulate to show there is such a prime..i should be able to figure it out from there ( hopefully)
(n+8)! - (n-1)! is very different from n(n+1)..(n+8). You mean (n+8)! / (n-1)!
Sorry, I should have said "between n and 2n".
Oh wow..you're right about the division..that was silly
Okay how about this:
We wish to prove n(n+1)(n+2)...(n+m) is not a perfect square. Assume to the contrary that it is a perfect square. Then, the prime factors can be written to an even power. However, this is a contradiction because there exists a largest prime (by bertrands postulate).
That's a dizzying leap of logic in the last line.
Does it work with m=0:wink:?
Consider also 8*9. All primes in there have powers > 1, it's just that one or more is odd. So I doubt the proof will be simple.
right...m>0...and your example just wrecked my proof completely :)... here's another try:
Assume G=n(n+1)(n+2)...(n+m) is a perfect square (m>0,n>0). Consider the set of prime factors of G: {p1,p2,...pn} where pn is less than or equal to m because if it were greater than m, G would have at most 1 factor of pn. Note that 2|G. Now we consider the repeated powers of each prime: 4 can divide G at most ...
This is where I get stuck. I would like to show the maximum number of times that pn^2 divides g (for each n) and then select from the remaining non repeating powers and conclude that the sequence contradicts the assumption of a prime larger than pn (the last n)...
No. There would only be one number in there that's divisible by pn, but it might be divisible an even number of times.
I think you'll find that for each prime factor of G there's no way to exclude the possibility that is has an even exponent in G. What seems to happen is that they can't all have even exponents.
9K
