Can a Magnetic Field Create Ions?
The discussion revolves around the influence of magnetic fields on liquids, specifically whether a magnetic field can ionize a solution. Participants explore theoretical implications and practical limitations of this phenomenon.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions if a magnetic field can ionize a solution and seeks clarification on the mechanism involved.
  • Another participant discusses the Lorentz force and its potential effect on ions in an ionic solution, suggesting that while theoretically possible, practical limitations may prevent effective ionization due to the required conditions.
  • A follow-up question is posed regarding the existence of an equation to measure the force of a magnetic field on current within an electrolytic solution.
  • A response indicates that the equations for the Lorentz force remain consistent regardless of the moving charge's location and suggests further reading on magnetohydrodynamics.
Participants do not reach a consensus on whether a magnetic field can effectively ionize a solution, with some expressing skepticism about the practicality of the concept while others seek further clarification and information.
Limitations include the dependence on specific conditions such as particle velocity and magnetic field strength, which are not fully explored in the discussion.
HelloCthulhu
Greetings again forum!
I have a question about the influence of magnetic fields on liquids. Can a magnetic field ionize a solution? If so, please explain how. Thank you!
Chemistry news on Phys.org
Magnetohydrodynamic generators operate on a similar principle. A Lorentz force is experienced by a charge moving through a magnetic field in the direction orthogonal to both its velocity and the magnetic field. For an ionic solution, each ion could (in theory) be separated by this effect assuming it were strong enough to overcome the complexing action of the liquid. In practice, it's doubtful that this force would be strong enough to perform enough work to ionize a solution since you'd need a hyper-fast particle velocity and an extremely strong magnetic field.
Thanks for your response! I really appreciate your input. I'd like to ask you another question. Is there an equation to measure the force of a magnetic field on current inside of an electrolytic solution? Thank you so much for your assistance. :]
Doesn't matter where the moving charge is, equations for the Lorentz force are always the same. I guess you should read about magnetohydrodynamics.
  • · Replies 22 ·
