What's the Paradox in Combining Sine and Cosine Series for Fourier Expansion?
The discussion revolves around the paradox of combining sine and cosine series for Fourier expansion, particularly focusing on the completeness of these functions as eigenfunctions of a Hermitian operator. Participants explore the implications of using only sine or cosine functions to represent arbitrary functions and the definitions of their coefficients.
  • One participant asserts that sine and cosine functions are degenerate eigenfunctions of a Hermitian operator and can form a complete set for function expansion.
  • Another participant argues that sine functions alone cannot expand non-odd functions, suggesting an error in the initial claim.
  • A different viewpoint emphasizes that sine series are odd functions while cosine series are even, questioning the assertion that coefficients for both series can be the same.
  • Some participants clarify that both sine and cosine functions are necessary to span the space of all functions in L2, indicating that using only one set is insufficient.
  • There is a discussion about the integration process used to derive coefficients for sine and cosine series, with some participants asserting that the same formulas apply to both series.
  • One participant challenges the notion of a paradox, asking for clarification on whether the claim is that the coefficients are equal, which they dispute.
  • Another participant highlights that while sine functions can span their respective space, they do not span the entire function space alone, necessitating the inclusion of cosine functions.
  • There is a mention of the need for all eigenfunctions to form a basis, suggesting that omitting any function would result in a non-spanning set.
Participants express disagreement regarding the completeness of sine and cosine functions in function expansion. While some argue that both are necessary for a complete representation, others question the validity of the initial claims about coefficients and the existence of a paradox.
Participants discuss the definitions of eigenfunctions, completeness, and the nature of function expansion without resolving the underlying assumptions or mathematical steps involved.
ShayanJ
Insights Author
We know that because [itex]\sin{nx}[/itex] and [itex]\cos{nx}[/itex] are degenerate eigenfunctions of a hermition operator(the SHO equation),and eachof them form a complete set so we for every [itex]f(x)[/itex] ,we have:
[itex] f(x)=\frac{a_0}{2}+\Sigma_1^{\infty} a_n \cos{nx}[/itex]
and
[itex] f(x)=\Sigma_1^{\infty} b_n \sin{nx}[/itex]
But here,because for every [itex]m[/itex],[itex]\sin{mx}[/itex] and [itex]\cos{mx}[/itex] are orthogonal,we also can have:
[itex] f(x)=\frac{a_0}{2}+\Sigma_1^{\infty} a_n \cos{nx} + \Sigma_1^{\infty} b_n \sin{nx}[/itex]
And its easy to understand that the [itex]a_n[/itex]s and [itex]b_n[/itex]s are the same.
So it seems we reach to a paradox!
What's wrong?
thanks
It's clear that for example the sum of sin(nx) is an odd function, so you can't expand a non-odd function with the sin(nx) only. Your statement in the first lime should be incorrect.
Sorry, I can't help solve the paradox.
A cosine series is a even function. A sine series is odd function.
If the 2nd function was called g(x) instead, then the third function is (f+g)(x).
And no, its not "easy to understand" what you mean by the coefficients being the same. They are defined differently. Why should they be the same?
The point is,[itex]\sin{nx}[/itex] are eigenfunctions of the hermition equation below:
[itex] \frac{d^2 y}{dx^2}+n^2 y=0[/itex]
So they should form a complete set and this means that every function can be expanded as a linear combination of them.The same is true for [itex]\cos{nx}[/itex]
And about the coefficients
We have:
if we multiply by [itex]\sin{mx}[/itex] and integrate from [itex]0[/itex] to [itex]2 \pi[/itex] we get:
[itex] \int_0^{2\pi} f(x) \sin{mx} dx = \Sigma_1^{\infty} \int_0^{2 \pi} b_n \sin{mx} \sin{nx} dx=b_m \int_0^{2 \pi} \sin^2{mx} dx=\pi b_m[/itex]
And so:
[itex] b_n=\frac{1}{\pi} \int_0^{2 \pi} f(x) \sin{nx} dx[/itex]
if you do the same for the Fourier series consisted of both sine and cosine terms,you get the same formula and Its the same for cosine.
Both sinnx and cosnx are the eigenfunctions of the hermitian equation. Doesn't this mean that sinnx and cosnx complete each other ? You expanded your function by half of a complete set.
Shyan said:
So they should form a complete set and this means that every function can be expanded as a linear combination of them. The same is true for [itex]\cos{nx}[/itex]
What I highlighted is plural, not singular they. You need both sine and cosine to span L2. You can't just discard half your answer.
We have:
And so:
So? And how is this relevant to your claim that there is a paradox?
Edit: Reading your post again, you haven't explained what your paradox actually is! Are you claiming that [itex]a_n = b_n[/itex]? Because that is simply wrong.
The sin(nx) are eigenfunctions of that equation. This doesn't mean they are spanning.
In fact, just sinx is an eigenfunction, but just sinx is not enough. They point is that we need all the eigenfunctions, so we need all the sin(nx) and all the cos(nx).
The whole point of these decompositions is that the eigenfunctions form a basis. If you remove even a single one, then the set is no longer spanning, and you don't have a basis anymore.
But for every [itex]m[/itex] , [itex]\sin{mx}[/itex] and [itex]\cos{mx}[/itex] are degenerate eigenfunctions.Doesn't that make a difference?
I mean making each of them spanning alone?
Each of them spans its spanning space not the entire space. You seem to be under the impression that any function in L2 can be written using a sine series or using a cosine series. That is not true. As pwsnafu said, cosine series span the space of all even functions in L2 and sine series span the space of all odd functions in L2. To get all functions in L2, you need both sine and cosine.
  • · Replies 33 ·
