What is the optimal torque angle for hardened head studs in a vehicle?
  • Thread starter Thread starter DieselDave
    Engine Head
The discussion revolves around determining the optimal torque angle for hardened head studs in a vehicle, with a focus on mechanical engineering and automotive applications. Participants explore the implications of using higher-grade, hardened studs compared to stock ones, particularly in terms of torque settings and yield strength.
  • One participant suggests that hardened studs should theoretically stretch the same amount as stock studs under load but may be torqued to a higher angle due to their hardness, raising questions about yield and malleability.
  • Another participant emphasizes the importance of yield strength over hardness, recommending loading to 95% of yield for reusability and suggesting that the angle of turn method could allow for scaling based on yield strength ratios.
  • A different participant notes that longer studs increase joint stiffness, which could be beneficial, and references Machinery's Handbook as a useful resource.
  • Concerns are raised about the potential for damaging female threads if the torque is increased without consideration of their strength, suggesting that thread engagement should be evaluated.
  • Another participant agrees on checking the female threads and mentions that using helicoils could provide a stronger solution if needed, while also advising that softer materials for female threads can help distribute the load better.
  • A link to a bolt calculator is provided for further analysis of torque and load relationships.
Participants express differing views on the relationship between hardness, yield strength, and optimal torque settings. There is no consensus on the best approach to determining the torque angle for the new studs, and multiple competing perspectives remain in the discussion.
Participants highlight the uncertainty in converting torque to load and the need to consider various factors such as thread strength and engagement. The discussion does not resolve these complexities.
DieselDave
Hi, can't believe I haven't discovered this forum until now - I would post in an introductions section, however I couldn't find one!
This question is loosely based around mechanical engineering, however may be applied to automotive, so apologies for posting in the wrong section.
I have had a set of hardened head studs made for my vehicle (for upgraded power/boost etc), the stock ones are grade 10.9, and the never ones should *in theory* be above 12.9 grade, by the by, they are stronger due to them being hardened.
My understanding is that in this situation, the newer hardened studs should stretch the same amount as the old studs under the same amount of loads, however due to their hardness and bearing hookes law in mind, they should purely be able to stretch further without yielding?, am I correct in my assumption?. Therefore would be able to be torqued to a higher torque angle than the stock bolts, applying a greater force on its respective load.
Stock torque angle is 220°, and with the newer bolts then a greater torque angle should be able to be acheived, without damage and yield of the bolts (assuming same conditions, bolt pitch, friction etc)
Or am I totally barking up the wrong tree here, and due to them being heat treated and hardened, this would reduce the malleability, therefore increasing the load on the bolts before yield point, although lower the malleability and ability for them to stretch as much before the yield point? so a higher clamping force will be achieved with less of a torque angle?
Any help on this subject would be greatly appreciated, here's and a photo of the new products.
Many thanks, dave
Don't care how hard they are. Care about their yield strength. Once you look that up, the ideal is to load them to 95% of yield if you want them to be reusable. Some engineering applications call for them to go past yield, but then they are one time use only.
If you use a torque wrench, then you must settle for a load much less than yield because of the great uncertainty in converting torque to load.
But if you are using the angle of turn method, then you can at least scale that up by the ratio of yield strengths of the old and new studs. If you learn the math required for the task, you may be able to go well beyond that.
All your assumptions based on Hook's Law are valid.
It is a good thing that your studs are so long. That increases your joint stiffness ratio, which does all sorts of good things for you. One of your best references is Machinery's Handbook. You should be able to look up everything you need in that.
Before just wanging up the torque, I'd have a look at the relative strengths of the threads.
By just upping the bolt strength, you can get to a point where you start winding out the female thread.
It's unlikely but something to bear in mind.
As Chris says, need to check but the female threads are probably good. The standard fix would be a helicoil, which would be much stronger. Look to see how much thread engagement you have. If it is at least 2D, I would not worry about it. It is always best if the female threads are cut into softer material so that they will yield and then more threads carry the load.
  • · Replies 18 ·
  • · Replies 0 ·
11K
