What Is the New Pulling Force When Wooden Blocks Are Stacked?
  • Thread starter Thread starter utkarshakash
    Blocks Friction
The discussion centers on calculating the pulling force required to move two stacked wooden blocks across a surface with friction. The force required to pull the blocks at a constant speed is denoted as F, with the frictional force calculated using the equation f = μN, where μ is the coefficient of kinetic friction and N is the normal force. The participants clarify the role of tension if the blocks are connected by a string and emphasize the importance of understanding the forces acting on the blocks to arrive at the correct answer.
  • Understanding of Newton's laws of motion
  • Familiarity with friction concepts, specifically kinetic friction
  • Knowledge of force equations, particularly f = μN
  • Basic algebra for solving equations
  • Study the effects of tension in connected systems in physics
  • Learn about static vs. kinetic friction and their applications
  • Explore Newton's second law of motion for multiple objects
  • Investigate real-world applications of friction in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to friction and force calculations in practical scenarios.
utkarshakash
Two similar wooden blocks are tied one behind the other and pulled across a level surface. Friction is not negligible. The force required to pull them at constant speed is F. If one block is stacked upon the other then the new force required to pull them at constant speed will be approximately ?
f=μN
F=f
I can't understand if they are connected by a string or something else. If a string is present then I will have to apply a Tension force. If they are just simply connected by some other means then the contact force has to be taken into account. By either way I am not able to get the answer.
welcome to pf!
hi utkarshakash! welcome to pf! :smile:
suppose the two blocks have mass m (each), the coefficient of kinetic friction is µ, and the tension is T …
since the acceleration is 0, what are the equations for the forces on the two blocks? :wink:
Thanks. I just got my answer.
  • · Replies 23 ·
