Bullet hits a block, penetration depth and velocity
The discussion centers on the physics problem of a bullet with mass m and velocity v penetrating a wooden block of mass M at rest on a frictionless surface. The common speed V of the bullet and block after the collision is derived using the conservation of momentum as V = mv/(m + M). The penetration depth l is calculated using the equation l = m(1 - m/(m + M))v²/(2F_{ret}), where F_{ret} is the constant retardation force opposing the motion. The equations provided are confirmed to be correct by participants in the discussion.
  • Understanding of conservation of momentum
  • Knowledge of kinetic energy principles
  • Familiarity with equations of motion under constant forces
  • Basic algebra for rearranging equations
  • Explore advanced topics in collision physics
  • Study the effects of varying retardation forces on penetration depth
  • Learn about energy loss in inelastic collisions
  • Investigate real-world applications of bullet penetration in materials
Students in physics, educators teaching mechanics, and professionals in materials science or ballistics who seek to understand the dynamics of projectile impacts.
AbigailM
A bullet with mass and speed v hits a wooden block of mass M that is situated at rest on a frictionless surface. It penetrates the block and gets trapped inside it as a result of a constant retardation force [itex]F_{ret}[/itex] that opposes relative motion between the two objects. Find the common speed of the bullet and the block V, and the penetration length l in terms of m, M, v, and [itex]F_{ret}[/itex].
mv=(m+M)V (Eq 1)
[itex]\frac{1}{2}mv^{2}=F_{ret}l+\frac{1}{2}(m+M)V^{2}[/itex] (Eq 2)
The common speed of m and M is [itex]V=\frac{mv}{m+M}[/itex] (Eq 3) via conservation of momentum.
[itex]\frac{1}{2}mv^{2}=F_{ret}l+\frac{1}{2}\frac{m^{2}v^{2}}{(m+M)}[/itex] (where I substituted Eq 3 into Eq 2)
Let's rearrange:
[itex]F_{ret}l=\frac{1}{2}m\left( 1-\frac{m}{m+M}\right) v^{2}[/itex]
No let's solve for the penetration depth l:
[itex]l=\frac{m\left(1-\frac{m}{m+M}\right) v^{2}}{2F_{ret}}[/itex]
Not sure if it is correct. Thanks for the help!
What is it that makes you doubt your answer?
mv=(m+M)V (Eq 1)
Let's rearrange:
Certainly your momentum and k.e. conservation equations are correct.
  • · Replies 26 ·
