Discover the Asymptotes of (x-1)^2: A Comprehensive Guide
  • Thread starter Thread starter frosty8688
The discussion revolves around finding the asymptotes of the function \( \frac{x}{(x-1)^2} \). Participants are exploring the definitions and characteristics of vertical and horizontal asymptotes in the context of this function.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the conditions under which asymptotes exist, questioning the definitions and relationships between limits and asymptotes. Some express confusion about the terminology used, particularly regarding the distinction between asymptotes and limits.
The conversation includes various interpretations of asymptotes, with some participants asserting the existence of a vertical asymptote at \( x = 1 \). Others are exploring the implications of the function's behavior as \( x \) approaches infinity or negative infinity, leading to a mix of opinions and clarifications regarding the definitions involved.
There is a noted confusion about the equation's format, as some participants point out the absence of an equals sign, which may affect the interpretation of the function. The discussion also highlights the need for clear definitions of asymptotes and their relationship to limits.
frosty8688
1.Find the asymptotes of the following equation.
2. [itex]\left.x/(x-1)^2\right.[/itex]
3. I know that the asymptote as x approaches ±∞ is ±∞. I am wondering when (x-1)[itex]^{2}[/itex] approaches ±∞ is also ±∞
To be an equation, there needs to be an = somewhere.
As x gets large or very negative, the denominator of x/(x - 1)2 is much larger than the numerator.
Now I think I know what you're trying to say. You seem to be using "asymptote" in place of "limit." The two words are not synonyms, and don't mean the same thing.
As x approaches ∞, both x and (x - 1)2 approach ∞. As x approaches -∞, x approaches -∞, but (x - 1)2 approaches +∞. Another way to say this is
$$\lim_{x \to -\infty} (x - 1)^2 = \infty $$
The thing is, the denominator gets large much more quickly than the numerator. One way to approach this problem is to factor x2 out of each term in the denominator, and factor x2 out of the numerator.
So there would be no asymptotes.
Do you understand what an asymptote is? How would you define it in your own words?
A vertical asymptote exists when x = a and a is determined by the values at which x is 0 and exists when f(x) = plus or minus infinity and a horizontal asymptote exists when x approaches infinity the number becomes larger and larger and if there is a denominator, the values when the x is in the denominator approach 0. So, there would be a horizontal asymptote at the x-axis. No vertical asymptotes, since the function approaches 0 as x goes to plus or minus infinity.
This is wrong. Take the denominator and set equal to 0 to find the vertical asymptote(s).
Vertical asymptote at x = 1.
Yes, that is correct. Do you understand why eumyang said
