Deflection - difference between pin and fixed joints
The discussion revolves around the differences between pin and fixed joints in structural frames, particularly focusing on their effects on deflection and member angles. Participants explore theoretical implications, practical examples, and the behavior of structures under load.
  • Some participants suggest that a fixed connection maintains a constant angle (90 degrees) between members, while a pin joint allows for differing angles, potentially leading to non-perpendicular members in the deflected shape.
  • There is a question about whether a pin joint is synonymous with a hinge, with some indicating that it can be considered as such, though real-world applications may involve semi-rigid connections.
  • Examples are requested to illustrate the differences between fixed and pin joints, with one participant describing a scenario involving columns and a beam to clarify the distinction.
  • Concerns are raised about the behavior of beams and columns under load, particularly how deflection may not be uniform across different members connected by pin joints.
  • Clarifications are made regarding the definition of rigid joints, with some participants noting that these joints do not allow for rotation between members, contrasting with pinned joints where angles may change under load.
  • A participant shares a sketch of a 3-hinged arch to illustrate the differences in behavior between rigid and pinned joints, emphasizing the importance of distinguishing between different types of displacements.
Participants express various viewpoints on the definitions and implications of pin and fixed joints, with no clear consensus reached on certain aspects, particularly regarding the behavior of structures under load and the interpretation of joint rigidity.
Some discussions involve assumptions about joint behavior that may not be universally applicable, and the definitions of rigid and pinned joints may vary based on context and specific engineering practices.
Individuals interested in structural engineering, mechanics of materials, and those studying the behavior of joints in frameworks may find this discussion relevant.
Sadeq
Deflection -- difference between pin and fixed joints
Hello all
I have a question regarding deflection. What is the difference between pin and fixed joint in frame l(first picture fixed the second pin),
I can summarize my question in points:
1.fixed connection introduces equal theta as picture indicates, because structure rotate in the same amount and the angle between to members will still 90,while pin joint, theta will differ , does this implies the 90 degree doesn’t satisfy??
2. Does pin joint means hinge or
3. Please give me example in reality illustrate both joints
4. Any additional information that could help is appreciable.
Many Thanks
Also another question regarding the same problem ,assume i have a beam and the internal support is pin, if we draw the deflected shape it will deflect and gives theta, right….., but imagine you have steel column connected to left beam and right beam by connection at web of beams (which means pin connection), here the right column will deflect and gives theta different than the left, while as i said previously in analysis, it deflect as one unit with one theta, so please explain this in details
Hope my question is clear
If my question is not clear i can explain it more!
Sadeq said:
Hello all
That's right, the members at the joint are no longer pependicular in the deflected shape.
ideally, yes, with a single bolt or pin connection. In actuality many multiple bolt connections are consisdered pinned, although they are semi rigid.
If you anchor 2 columns at the base a distance L apart, and attach a beam to the column tops using a single bolt at each end, that's a pinned joint; if you instead weld that beam to the columns with a full penetration weld, that's a fixed joint.
I'm not sure what you mean, but your pictures tell the story.
Thank you very much.
So when we sau rigid joint ,that implies fixed one, which always considerd in structural engineering book...Right
A rigid joint is one where the members that frame into the joint do not rotate relative to each other at that joint. If a member frames into another member say at a 60 degreee angle, they remain at 60 degreees to each other at that joint under loading or rotation or translation of that joint. I'm not sure about the handbook question...not all joints are rigid, like when a beam frames into a column and is attched to the web of the column with clip angles, it is assumed pinned, in which case if the angle between them was 90 degrees before loading, it is no longer 90 degrees when the beam is loaded, it would be slightly less.
I don't know if this helps but I have attached a hand sketch of the exaggerated deflection of a 3-hinged arch in which the left hand knee is rigid and the right hand knee is pinned. The exaggerated nature of the sketch shows the beam bending, but also a small sway to the right to accommodate the difference in behaviour between right and left sides. In interpreting this figure it is important to distinguish between first order displacements (central deflection of beam bending, and beam end rotations) from second order displacements (lateral sway, column bending). Practically the columns remain straight.
thank you brother
