Parametric equations, find speed and direction
The discussion focuses on calculating the speed and direction of an object defined by parametric equations at a specific time, t = 3 seconds. The coordinates are given as x = 25t and y = 20t - 5t². The velocity components are derived as dx/dt = 25 and dy/dt = 20 - 10t, leading to the velocity vector v. At t = 3 seconds, the speed is calculated using the formula v = √((dy/dt)² + (dx/dt)²), resulting in a definitive speed and direction for the object.
  • Understanding of parametric equations
  • Knowledge of calculus, specifically derivatives
  • Familiarity with vector components
  • Application of the Pythagorean theorem in physics
  • Calculate the speed of the object at t = 3 seconds using the derived velocity components.
  • Explore the concept of velocity vectors in two-dimensional motion.
  • Learn about acceleration in parametric equations and how it affects motion.
  • Investigate real-world applications of parametric equations in physics.
Students studying physics, particularly those focusing on motion in two dimensions, as well as educators looking for examples of parametric equations in action.
Mushroom79
An object moves so it's coordinates at the time t is given by the relationships
x = 25t
y = 20t-5t^2
What is the object's speed and direction at 3 sec?
t = 3 sec
v = √(dy/dt)^2 / (dx/dt)^2
Pythagoras theorem
dx=25
dy=20-10t
I'm not sure how I should use this by combining the two formulas above.
x = 25t
y = 20t-5t^2
t = 3 sec
Pythagoras theorem
dx=25
dy=20-10t
What you are calling dx and dy are really
[tex]\frac{dx}{dt} \text{ and } \frac{dy}{dt}[/tex]
which is the same as vx and vy. So you have found the two components of the velocity vector v -- or at least you'll have them once you plug the time value into your expression. So as a start, figure out what the values of vx and vy are, using the expressions you got.
Ah, but that is the part I get stuck on,
√25^2+(20-10t)^2
  • · Replies 29 ·
