Help with a linear differential equation
The discussion revolves around solving a specific linear differential equation of the form [ D^6+a D^4+b D^2+(c-d sech^2(x))] y=0, where D represents the derivative operator and a, b, c, d are constants. Participants explore methods for both the homogeneous and non-homogeneous aspects of the equation, considering the implications of the presence of the function y in the non-homogeneous term.
  • One participant inquires about general methods for solving the given linear differential equation.
  • Another participant identifies the equation as having constant coefficients and discusses the characteristic equation, suggesting a quadratic approach to find roots.
  • It is noted that the presence of double roots may lead to additional solutions involving powers of x.
  • Participants discuss the non-homogeneous part of the equation, with one suggesting the method of "variation of parameters" for finding a particular solution.
  • Concerns are raised about treating the term (c-d sech^2(x))y as non-homogeneous due to the presence of y, leading to uncertainty about the approach.
  • A later reply suggests that the equation is now one with variable coefficients and proposes using a power series expansion as a potential method for handling it.
Participants express differing views on how to approach the non-homogeneous part of the equation, particularly regarding the implications of the presence of y. There is no consensus on a single method to solve the equation, indicating that multiple approaches may be valid.
The discussion highlights limitations related to the treatment of the non-homogeneous term and the implications of variable coefficients, which remain unresolved. The specific values of constants a, b, c, and d are not provided, which may affect the applicability of proposed methods.
This discussion may be useful for students or practitioners dealing with linear differential equations, particularly those interested in methods for solving equations with both constant and variable coefficients.
Sagar_C
Is there any general method to solve the following linear equation:
[ D^6+a D^4+b D^2+(c-d sech^2(x))] y=0?
Here, D=d/dx and a,b,c,d are constants.
That's a linear equation with constant coefficients. it characteristic equation is [itex]D^6+a D^4+b D^2= 0[/itex] (we are now thinking of "D" as a number, not a derivative operator). You can obviously factor out [itex]D^2[/itex] leaving [itex]D^4+ aD^2+ b= 0[/itex], a quadratic equation in [itex]D^2[/itex] so, using the quadratic formula, [itex]D^2= \frac{-a\pm\sqrt{a^2- 4b}}{2}[/itex] and then find D by taking the square root of each of those. The fact that D is a double root of the characteristic equation means that two solutions are a constant and x. For given values of a and b, 0 may b a triple or higher root which would give additional powers of x. For non-zero roots, of the form a+ bi, there will be solutions of the form [itex]e^{ax}(A cos(bx)+ B sin(bx))[/itex] for constants A and B. You will need six independent solutions.
As for the "non-homogeneous" part, try "variation of parameters": http://www.sosmath.com/diffeq/second/variation/variation.html
Thanks. Just to double-check, so I can treat (c-d sech^2(x))y as the non-homogeneous part even though it contains y? I actually knew how to solve it (as particular solution) when y is absent but not when y is present. :(
Blast! I didn't see that "y". That is still a linear equation but now with "variable coefficients. Probably the simplest way to handle it is through a power series expansion.
  • · Replies 52 ·
10K
  • · Replies 0 ·
