Charging a Capacitor: Explained & Questions
  • Context: Undergrad
  • Thread starter Thread starter Eugbug
    Capacitor Charge
The discussion focuses on the charging mechanism of capacitors, specifically addressing the role of dielectrics and the behavior of charges. When a capacitor is charged, an electric field is created between the plates, leading to a potential difference. The presence of a dielectric material allows for internal dipoles to align, enhancing the capacitor's capacity by reducing the electric field strength compared to a vacuum. The discussion clarifies that charges do not return to their original state immediately after the voltage is removed, unlike a spring, due to the nature of electric fields and charge separation.
  • Understanding of electric fields and potential difference
  • Familiarity with capacitor construction and function
  • Knowledge of dielectric materials and their properties
  • Basic principles of charge separation and alignment
  • Research the effects of different dielectric materials on capacitor performance
  • Explore the mathematical relationship between capacitance, voltage, and charge
  • Learn about the role of electric fields in capacitor circuits
  • Investigate the behavior of capacitors in AC versus DC circuits
Electrical engineers, physics students, and anyone interested in understanding capacitor functionality and applications in electronic circuits.
Eugbug
Can someone explain what exactly happens when a capacitor is charged?
At the positive plate, are loosely bound electrons pulled onto the plate from the dielectric or are whole molecules in the dielectric rotated and orientated so that the negative part of the molecule is close to the plate? Why don't electrons return to their rest position after the charging voltage is removed just like a spring returns to a zero displacement state when a force is removed? Also how can a capacitor work when the dielectric is a vacuum? If the dielectric is removed, does the charge disappear?
Which molecules/electrons do you mean, and where? In the dielectric between the plates?
You should begin with this case, it is required to understand the situation with material inside.
The opposite charges on the plates create an electric field in between, this leads to a potential difference. You can exploit this difference in a circuit, for example - you give the charges (here: electrons on the negative side) a way to go to the other, positive, side.
Now, a material between the plates can have internal dipoles or other methods of charge separation. Those dipoles will align their orientation in a charged capacitor. This gives an effective (smaller) negative charge at the positive side and an effective (smaller) positive charge at the negative side. This reduces the electric field strength and therefore the voltage, compared to vacuum. In other words, you need more charges for the same potential difference, the capacity increased.
  • · Replies 16 ·
  • · Replies 42 ·
