What is the use of converting a circuit into its dual?
  • Thread starter Thread starter Avichal
    Circuits
The discussion revolves around the concept of circuit duality, specifically the use and applications of converting a circuit into its dual. Participants explore the theoretical underpinnings, practical applications, and the relevance of duality in circuit analysis.
  • One participant expresses confusion about the concept of circuit duality and its practical uses, noting a lack of clear resources.
  • Another participant questions the terminology used, pointing out that a resistor is inherently a conductor.
  • Several participants inquire about specific applications of duality, particularly in relation to Thévenin's and Norton's theorems.
  • It is mentioned that Thévenin's and Norton's theorems are duals of each other, along with wye-mesh transformations.
  • One participant explains that understanding duality can enhance comprehension of system behavior, citing examples like parallel RC and series RL circuits being duals.
  • There is a discussion about the historical context of analog systems and how electrical components can model mechanical systems, emphasizing the practical applications of duality in system analysis.
  • A later reply notes that while the relevance of this analysis has diminished with modern computing, it remains an interesting topic to explore.
Participants express varying levels of understanding and agreement regarding the concept of duality. While some acknowledge its theoretical significance, others question its practical applications and relevance, indicating that the discussion remains unresolved.
Participants reference specific theorems and transformations without fully resolving the definitions or implications of duality. The discussion highlights a lack of consensus on the importance and utility of converting circuits into their duals.
Avichal
I just do not understand this concept. My book doesn't explain it clearly nor do I find anything useful on Wikipedia.
So what is it used for? I know the steps to convert - like changing voltage source to current source, resistor to conductor etc. But why am I doing it? What is the use?
I have no real idea what you are referring to ... a resistor is already a conductor
can you give a specific application of this "duality" you refer to please :)
Dave
Are you referring to Thevenin and Norton's theorems?
Here is the link. I don't think it is an important topic hence so less resources available
Dave
I am also looking for its application :)
Well your not important pages states most of the important formulae in electrics.
Every one of those formulae are vitally important.
What exactly did you want to know?
Well I encountered some questions where I have to convert circuit into its dual. So basically what I am asking is the use of converting a circuit into its dual.
I've never heard it called "duality" but he must mean, Thévenin's theorem and it's extension Norton's theorem.
dlgoff,
Have you looked at the link provided by the OP?
Yes Norton's and Thevenins theorems are duals of each other as are for instance wye - mesh transformations.
Studiot said:
dlgoff,
I have now. :redface:
Nowadays, mainly to increase your understanding of system behavior, such as a parallel RC and and series RL circuit being duals of each other, where current and voltage will behave similarily from one to the other. Resitance -> conductance, inductance -> capacitance, parallel -> series, voltage source -> current source and vice-versa.
You might want to look up analog systems, where the behavior of a mechanical system can be modeled as an electrical system ( also valid for thermal, mechanical, electrical, fluid ).
The analog, dualog was used extensively many years ago since electrical systems could be more readily made from components and system behavior observed. Resisters, capacitors, inductors could easily exchanged to vary system behavior. Try that with not so readiy available components for a mechanical system. A mechanical system could be modeled as electrical and observed. Thevin and Norton could readily be applied.
The advent of the analog and then the digital computer has depreciated this type of analysis, but it is still interesting to know how systems relate to one another.
  • · Replies 32 ·
  • · Replies 32 ·
