Wronskian and linear independence
The discussion revolves around the concept of linear independence of functions and their derivatives, specifically focusing on the implications of the Wronskian determinant in determining linear independence. Participants explore the relationships between a set of functions and their derivatives, questioning whether linear independence of the original functions guarantees linear independence of their derivatives.
  • One participant states that three functions f, g, and h are linearly independent if the only solution to the equation (c1)f + (c2)g + (c3)h = 0 is c1 = c2 = c3 = 0.
  • Another participant questions whether it is possible for f, g, and h to be linearly independent while their second derivatives f'', g'', and h'' are linearly dependent, suggesting this could lead to an inconsistent Wronskian.
  • A participant proposes that if f' and g' are linearly dependent, then f and g must also be linearly dependent, indicating a potential relationship between the linear dependence of functions and their derivatives.
  • Another participant corrects the previous claim regarding integration, noting that arbitrary constants can affect linear dependency when integrating functions.
Participants express uncertainty regarding the implications of linear independence for derivatives and whether linear independence of functions guarantees the same for their derivatives. There is no consensus on these points, and multiple views remain present.
The discussion highlights the complexity of relationships between functions and their derivatives, particularly in the context of linear independence and the role of the Wronskian. Limitations include the dependence on definitions of linear independence and the impact of arbitrary constants in integration.
dumbQuestion
Hello,
I understand that if we have three functions f, g, and h, they are linearly independent <=> the only c1, c2, and c3 that satisfy (c1)f+(c2)g+(c3)h=0 are c1=c2=c3=0.
In order to solve for these c1, c2, and c3, we want three equations in the three unknowns. To do this we can differentiate f, g, and h twice and construct the Wronskian. Since this is a square matrix, if the det(W =/= 0, then we know that this system is nonsingular, consistent, and the solution is unique. Furthermore, since its homogeneous we know that unique solution must be c1=c2=c3=0. So if this is the result, we know f,g, and h are linearly independent. But that also means that f', g' and h' are linearly independent, and f'', g'', and h'' are linearly independent, right?
I guess my confusion is, what if there are functions f,g, and h such that f, g, and h are linearly independent but say, f'', g'' and h'' are linearly dependent? Wouldn't this mean if we construct the Wronskian it will end up inconsistent even though f, h, and h are linearly independent? Is it even possible for that to happen?
Sorry if the question is confusing.
The derivative of ##c_1 f + c_2 g + c_3 h## is just ## c_1 f' + c_2 g' + c_3 h'##, because the c's are constants.
So the functions are linearly dependent if and only if the derivatives are linearly dependent.
ok I want to make sure I understand. Is the reasoning something like this.
let's assume f' and g' are linearly dependent.
this means f' = (c)g' for some constant c
So then we can integrate both sides
∫f' = ∫(c)g'
∫f' = c∫g'
f = (c)g
Which means f and g have to be linearly dependent as well.
So pretty much if functions are differentiable and linearly dependent, their derivatives are linearly dependent also? And if functions are integrable and linearly dependent, their antiderivatives are linearly dependent also?
Well, this doesn't work for integration, because you forgot about the arbitrary constants and they might mess up the linear dependency.
But you have got the general idea about what's going on.
ok, thank you very much. this clears up the confusion I had!
  • · Replies 23 ·
  • · Replies 0 ·
