Equation of motion: spring mass system - free undamped vibration
The discussion revolves around the equation of motion for a spring-mass system undergoing free undamped vibrations. Participants are examining the relationship between inertial forces, acceleration, and the direction of motion within the context of the system's dynamics.
  • Participants explore the definition of inertial force and its relationship to acceleration and motion. Questions arise regarding the correct interpretation of forces acting on the mass as it moves away from equilibrium in both positive and negative directions.
Some participants have provided clarifications regarding the direction of forces and acceleration, while others express confusion about the implications of their chosen coordinate system. The discussion is ongoing, with participants seeking to solidify their understanding of the concepts involved.
There is a mention of a specific website that may have contributed to some misunderstandings regarding the definitions of forces. Participants are also grappling with the implications of their coordinate choices on the equations of motion.
jason.bourne
i have uploaded my question. please check out the attached .pdf file.
Shouldn't the 'inertial force' oppose the acceleration, not the motion?
hey! thanks for replying.
i was following this website. here's the link
http://lpsa.swarthmore.edu/Systems/MechTranslating/TransMechSysModel.html
it has been mentioned in this website that 'inertia force acts opposite to the direction of motion'.
did i understand it right?
mass will decelerate in the positive x direction, when it moves away from equilibrium towards +A.
it will accelerate in the negative x direction, when it is moving towards the equilibrium position.
it will start decelerating in the negative x direction, when it moves away from equilibrium position towards -A.
it will start accelerating in the positive x direction, when it moves towards equilibrium position.
I think it's just a sloppy and misleading way to describe the direction. Note how they 'derive' the inertia force: It's just the negative of 'ma'.
Since your variable x already defines the positive direction of acceleration, [itex]\ddot{x}[/itex], the inertia force is simply [itex]-m\ddot{x}[/itex]. The direction is already included: When the sign of [itex]\ddot{x}[/itex] changes, so will the sign of the inertia force.
But it's the direction of the acceleration that determines the direction of the inertia force, not the direction of motion.
Since your variable x already defines the positive direction of acceleration, x¨, the inertia force is simply −mx¨
as i defined downward x as positive, so does that mean x¨ is positive as i move downwards away from equilibrium?
i might be asking really very silly doubt but this thing is really confusing me. i want it to be sorted.
as the mass moves away from equilibrium towards +A in the downward positive x direction, if we draw a free body diagram, how do we represent acceleration?
if we take x¨, acceleration positive in the downward direction, the inertia force acts in the opposite direction i.e, upwards.
so if i write equation of motion using D'Alembert's Principle, i get:
-mx¨ - kx = 0.
but if i consider the situation where the mass is at a position, away from -A, towards equilibrium, then what is the direction of acceleration and how do i write the equation of motion?
[itex]\ddot{x}[/itex] is positive as long as the acceleration is in the positive direction, which you have defined as downward. Note that the restoring force of the spring always acts to accelerate the mass back towards the equilibrium point. So at any point below the equilibrium point, the acceleration would be upward.
You wouldn't put the acceleration on a free body diagram, but it would act upward.
[itex]\ddot{x}[/itex] would be negative and the inertia force would be positive. But you don't have to worry about the inertia force direction--you'd still represent that inertia force as [itex]-m\ddot{x}[/itex].
-mx¨ - kx = 0.
Right.
So now you are looking at the situation when the mass is above the equilibrium point. So the spring force acts downward and the acceleration is downward.
Nonetheless, you'd still write the restoring force as -kx (since x is now negative, the force comes out positive). And you'd still write the inertial force as opposite to the acceleration: [itex]-m\ddot{x}[/itex]. (Since the acceleration will be positive, that will come out to be negative.)
So the equation of motion will be exactly the same. Realize that you don't have to know the direction of the acceleration ahead of time. Just represent the inertia force properly--with respect to your chosen coordinates. Then your equation of motion will tell you the direction of the acceleration.
thanks Doc Al. i think i got it.
if i have any doubts further, i'll get back to you.
thank you very much!
Excellent. Glad that it helped. And you are most welcome.
  • · Replies 31 ·
