Why is Diethylamine a Stronger Base Than Dimethylamine?
  • Thread starter Thread starter Saitama
    Basicity
The discussion revolves around the comparative basicity of diethylamine and dimethylamine, focusing on their pKb values in aqueous solution. Participants explore the factors influencing basicity, including steric hindrance, solvation effects, and the inductive effect of alkyl groups.
  • Homework-related
  • One participant notes that diethylamine has a lower pKb value than dimethylamine, suggesting it is a stronger base, but questions the reasoning behind this.
  • Another participant argues that dimethylamine is more easily protonated due to less steric hindrance and is more solvated because of its smaller size, which could indicate it is a stronger base.
  • Inductive effects are discussed, with one participant suggesting that the +I effect of -C2H5 in diethylamine stabilizes the protonated form more than the -CH3 in dimethylamine, potentially supporting diethylamine's stronger basicity.
  • One participant emphasizes that the dominance of these effects can only be determined experimentally, suggesting that stabilization from electron-donating groups is more significant than solvation effects in this context.
  • Another participant mentions that while comparisons can be made between ethylamine, diethylamine, and triethylamine, the comparison between trimethylamine and triethylamine is less straightforward due to steric hindrance and hydration effects.
Participants express differing views on which factors most significantly influence the basicity of diethylamine and dimethylamine, indicating that the discussion remains unresolved with multiple competing perspectives.
Participants acknowledge that the analysis is context-dependent, particularly regarding the aqueous medium, and that the effects of steric hindrance and inductive effects may vary in significance.
This discussion may be useful for students studying amine chemistry, particularly those interested in the factors influencing basicity and the comparison of different amines.
Saitama
This is no homework question, i came across this when i was checking out the pKb values for some amines. The pKb value of diethylamine is less that of dimethylamine in aqueous phase according to my textbook. This indicates that the former is more basic. My question is why diethylamine is a stronger base than dimethylamine?
What i think is when the latter is protonated, it is easily protonated because of less steric hindrance. Also, the protonated dimethylamine is more solvated than the protonated diethylamine due to its smaller size. These two factors support that dimethlylamine is a stronger base.
Next comes the inductive effect, the +I effect of -C2H5 is greater than that -CH3 due to which protonated diethylamine is more stable than the protonated dimethylamine. This supports that diethylamine is a stronger base.
How should i determine the basicity order here when two factors support that dimethylamine is a stronger base than diethylamine but one factor supports that diethylamine is stronger base than dimethylamine?
Any help is appreciated. :smile:
Chemistry news on Phys.org
Anyone?
Is there no one who could help me with my simple question? :(
This is not something that can be quantitatively analyzed just from knowledge of the above two factors. Which effect dominates can only be found out experimentally, and in this case stabilisation due a more electron-donating group is more important than cation solvation (I assume all this is in an aqeous medium).
mishrashubham said:
This is not something that can be quantitatively analyzed just from knowledge of the above two factors. Which effect dominates can only be found out experimentally, and in this case stabilisation due a more electron-donating group is more important than cation solvation (I assume all this is in an aqueous medium).
Finally someone replied! Thanks Shubham! :smile:
Yes, everything is in aqueous medium, i already mentioned that.
But what if a question appears on these two amines? Am i supposed to memorize the pkb values? For example, if i wanted to determine which is more basic from, say, triethylamine and trimethylamine in aqueous medium, how should i go on answering it?
You can compare between Ethylamine, diethylamine or triethylamine, but the problem is, you can't readily compare between trimethylamine or triethylamine. But, since you know the comparison between dimethylamine and diethylamine, you can solve this question.
You may probably know, trimethylamine as well as triethylamine, both are weaker than their "di" counterparts. (Look into NCERT). Now triethylamine do not take the hit as bad as trimethylamine, because steric hindrance can't go worse (affecting hydration), so the stabilization of cation by +I groups matters, so TEA > TMA.
Thanks AGNuke for the explanation, i get it now! :smile:
Btw, this question is from NCERT, i mean i was checking out the pkb values from the chapter "Amines" and stuck on these.
11K
