What can be the maximum velocity
  • Thread starter Thread starter utkarshakash
    Maximum Velocity
The discussion centers on a physics problem involving a shell with an initial velocity of 500 m/s that bursts into three identical fragments, resulting in a kinetic energy increase of 1.5 times. The conservation of momentum and energy principles are applied to derive the maximum velocity of one fragment. The maximum velocity occurs when two fragments move in opposite directions relative to the center of mass, allowing the third fragment to achieve the highest possible speed. The solution involves setting up two equations: one quadratic for energy and one linear for momentum.
  • Understanding of conservation of momentum
  • Knowledge of conservation of energy principles
  • Familiarity with kinetic energy calculations
  • Ability to solve quadratic and linear equations
  • Study the principles of conservation of momentum in explosive scenarios
  • Learn about kinetic energy transformations during collisions
  • Explore advanced problem-solving techniques for physics equations
  • Review examples of similar physics problems involving explosions and fragment velocities
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for illustrative examples of momentum and energy principles in action.
utkarshakash
A shell flying with velocity v = 500 m/s bursts into three identical fragments so that the kinetic energy of the system increases η = 1.5 times. What maximum velocity can one of the fragments obtain?
Conservation of Momentum
Conservation of Energy
[itex]K.E._{initial}=\frac{1}{2} mv^{2}[/itex]
Let final velocities be [itex]v_{1}, v_{2} and v_{3}[/itex]
[itex]K.E._{final}=\frac{1}{2} \left[ \frac{m}{3} v_{1}^{2}+ \frac{m}{3} v_{2}^{2}+ \frac{m}{3} v_{3}^{2}\right][/itex]
From question
[itex]K.E._{final}= η K.E._{initial}[/itex]
Putting the values of K.E. I get a relation
[itex]=3v^{2}η = v_{1}^{2}+ v_{2}^{2}+ v_{3}^{2}[/itex]
Also using conservation of momentum
[itex]mv = \frac{m}{3}\left(v_{1}+v_{2}+v_{3}\right)[/itex]
which simplifies to
[itex]3v = (v_{1}+v_{2}+v_{3})[/itex]
But now I'm stuck here. What to do next to find the maximum velocity?
The maximum velocity will occur if two pieces fly off in a direction opposite the third piece. When something explodes in flight, the center of mass follows the same path as before the explosion. So assuming the projo is going to the right, the maximum velocity will occur if two pieces are sent to the left relative to the center of mass (one upward and to the left while the other is downward and to the left). The horizontal component of velocity of the two pieces going to the left are equal. The vertical components are equal and opposite. Conservation of momentum then imparts the maximum velocity to the remaining piece that moves horizontally to the right.
Set this up and you'll arrive at two equations and two unknowns. The energy equation will be quadratic while the momentum equation will be linear.
Thanks. I got my answer correct.
