What is the Definition of Closed Sets in Topology?
The discussion revolves around the definition of closed sets in topology, particularly in the context of subsets of the real numbers ℝ and the rational numbers ℚ. Participants examine the implications of boundary points and the closure of sets, exploring whether certain subsets can be considered closed based on their boundary properties.
  • One participant argues that a subset S of ℝ is not closed if it contains all its boundary points, using the example S={xεQ;0≤x≤2} to illustrate that its closure is [0,2], which is not equal to S.
  • Another participant questions whether √2 is a boundary point of S and whether it belongs to S, highlighting the nature of boundary points in relation to the set.
  • A different participant notes that due to the density of Q in ℝ, every irrational number between 0 and 2 is a boundary point of S, reinforcing the claim that S is not closed as it does not include these irrational numbers.
  • One participant mentions the importance of the topological space being considered, stating that in the space Q, the closure of S is S, while in R, the closure is [0,2].
  • Another participant elaborates that the concept of "closed subset" is relative to the topological space, contrasting it with properties like compactness, which are intrinsic.
Participants express disagreement regarding the definition and properties of closed sets, particularly in relation to boundary points and the spaces in which the sets are considered. No consensus is reached on the implications of these definitions.
The discussion highlights the dependence on the definitions of closed sets and the topological spaces involved, indicating that conclusions may vary based on the context.
kimkibun
Good day!
Im currently reading the book of Steven R. Lay's "Analysis with an Introduction to Proof, 3rd ed.". According to his book, if a subset S of ℝ contains all of its boundary then it is closed. But i find this wrong since if we consider S={xεQ;0≤x≤2}, then it can be shown that S contains all of its boundary points (using the fact the Q is dense in ℝ), but it is not closed since the closure of S is the interval [0,2] which is not equal to the set itself. am i correct?
kimkibun said:
Good day!
Is √2 a boundary point of S? Is it in S?
Because, as you say, Q is dense in the real numbers, every irrational number between 0 and 2 (in fact, every number in S as well) is a boundary point, not just 0 and 2. S is NOT closed because it does not contain the irrational numbers. The closure of S is the interval [0, 2] including all rational and irrational numbers in that interval.
May not be relevant, but you should also check which "space" you are in. In the space Q, the closure of S is S. In R, the closure of S is [0,1].
Elaborating on algebrat's response, "closed subset" is a relative concept, depending on what topological space that subset is embedded in. (Obviously "open subset" is relative to the larger space as well.) This is in contrast to a property like compactness, which is intrinsic.
10K
