Orientation Forms in Different Codimension.
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Forms Orientation
The discussion revolves around defining orientation forms for manifolds of varying codimension, particularly focusing on codimension-1 and higher-dimensional cases. Participants explore the mathematical frameworks and concepts involved in these definitions, including the role of normal bundles and volume elements in Euclidean space.
  • One participant proposes a method for defining an orientation form for a codimension-1 orientable manifold using a normal vector and an orthogonal basis for the tangent space.
  • Another participant suggests that if the normal bundle to a submanifold is trivial, an orientation form can be obtained by contracting the orientation form of the ambient manifold with linearly independent normal vector fields.
  • There is a discussion about the triviality of the normal bundle for hypersurfaces in Euclidean space, with one participant expressing uncertainty about direct proofs but willing to collaborate on the topic.
  • A participant mentions the possibility of using the Thom class of the normal bundle to explore orientation forms further.
  • Another contribution suggests contracting the volume element of the ambient manifold by a local orthonormal basis for the normal bundle to obtain a local volume form for the submanifold.
  • One participant asserts that if the normal bundle is orientable, then the submanifold must also be orientable, and another participant agrees with this statement.
  • There is a broader claim that if a vector bundle splits into two subbundles, the orientability of two of them implies the orientability of the third.
Participants express varying degrees of agreement on certain points, particularly regarding the relationship between the orientability of the normal bundle and the submanifold. However, there remains uncertainty and exploration around the definitions and implications for higher codimensions, indicating that multiple competing views exist.
Some participants express uncertainty about specific proofs and methods, indicating that the discussion is ongoing and that there may be limitations in the assumptions made regarding the normal bundles and their properties.
WWGD
Hi, Everyone:
A way of defining an orientation form when given a codimension-1 ,
orientable n-manifold N embedded in R^{n+1} , in which
the gradient ( of the parametrized image ) is non-zero (I think n(x)
being nonzero is equivalent to N being orientable), is to
consider the nowhere-zero normal vector n(x), and to define the
form w(v)_x : = | n(x) v1 , v2 ,...,v_n-1| (**)
Where {vi}_i=1,..,n-1 is an orthogonal basis for T_x N , written
as column vectors, and n(x) is the vector normal to N at x , so that we write:
| n_1(x) v_11 v_21... v_n1|
| n_2(x) v_12 v_22...v_n2|
|n_n(x) v_1n v_2n...v_nn|
For vi= (vi1, vi2,...,vin )
Then the vectors in (##) are pairwise orthogonal, and so are
Linearly-independent.
*QUESTION* : How do we define a form for a curve of codimension-1,
and, in general, for orientable manifolds of codimension larger-
than 1 ? I have seen the expression t(x).v , meaning <t(x),v> ,for the curve. But the
tangent space of a curve is 1-dimensional, so, how is this a dot product?
Also, for codimension larger than one: do we use some sort of tensor contraction?
Thanks.
Thanks.
If the normal bundle to the submanifold is trivial then you can get an orientation form by contracting the orientation form of the ambient manifold by a smooth set of lineally independent normal vector fields.
In Euclidean space you contract the standard volume element.
If the normal bundle is not trivial i am not sure off of the top of my head but let's see if we can figure it out. It shouldn't be hard.
The normal bundle of a hypersurface (closed without boundary, codimension 1) of Euclidean space is always trivial but I do not know a direct proof and again would like to work on it with you. I do know a nasty indirect proof if you would like to see it.
Sure, I'll work on it with you. Do you have any suggestions/format in mind?
Just looking at ideas plus some reading. My first thought is to see if there is something that can be dome with the Thom class of the normal bundle to the submanifold.
I think you can Just contract the volume element of the ambient manifold by a local orthonormal basis for the normal bundle over each coordinate chart. Over each chart you get a local volume form for the submanifold and since the coordinate transformations are in SO(n) they should piece together to give you a global orientation for on the submanifold. Is this right?
BTW: it follows that if the normal bundle is orientable then the submanifold must be orientable as well.
I think this is correct. Well done lavinia!
More generally, I think if a vector bundle E splits as a direct sum of two subbundle F and G, then 2 of them are orientable iff the third one is.
  • · Replies 73 ·
9K
  • · Replies 36 ·
