How do we deal with the poles in QCD form factors?
Form factors in Quantum Chromodynamics (QCD) are expressed as "f(q^2)=f(0)/(1-q^2/m^2)", indicating a pole at q=m. To effectively plot these form factors against center of mass energy, it is essential to introduce a small negative imaginary part to the mass, similar to QED propagators. The standard dipole form factor, represented as G(Q^2) ∼ 1/(1+Q^2/μ²) with μ² = 0.71 GeV/c², deviates from reality for Q² < 0. The analytical continuation of form factors into the complex q² plane reveals a complex cut structure, with the first cut opening at q² = (2mπ)², marking the threshold for pion pair production.
  • Understanding of Quantum Chromodynamics (QCD) principles
  • Familiarity with form factor definitions and their mathematical representations
  • Knowledge of complex analysis, particularly Riemann surfaces
  • Experience with scattering experiments, specifically electron scattering
  • Research the implications of the standard dipole form factor in QCD
  • Explore the analytical continuation of form factors in the complex q² plane
  • Study the threshold for pion pair production and its significance in particle physics
  • Investigate dispersion relations and their applications in QCD form factors
Particle physicists, theoretical physicists, and researchers focusing on Quantum Chromodynamics and form factor analysis in scattering experiments.
plasmon
Form factors in QCD are given in following form "f(q^2)=f(0)/(1-q^2/m^2)". This expression has a pole at q=m. How do we plot these form factors vs center of mass energy and deal with the pole.
I hope mass is still given a small negative imaginary part to deal with like qed propagators.May be it is not right with form factors.
The electric (magnetic) form factor are measured via electron scattering i.e. via one-photon exchange between the electron and the charge (current) density of the hadron. Usually form factors are introduced as Fourier transform of the charge (current) density; but this picture is rather misleading when applied to non-perturbative QCD.
For Q² = -q² > 0, qμ is the 4-momentum transfer, the form factors do not have poles for spacelike, physical values of Q². The above mentioned equation should read
[tex]G(Q^2) \sim \frac{1}{1+Q^2/\mu^2}[/tex]
The world data fit for μ² is 0.71 GeV/c². This is the standard dipole form factor; in reality the hadron form factors deviate from this simple form.
The definition of the form factors can be analytically continued to the complex q² plane. Here poles are excluded on the first q² sheet in the complex plane. It is expected that for timelike q² there is a complicated cut structure of a Riemann manifold in q² with multiple sheets. The first cut opens at q² = (2mπ)² which is the threshold for pion pair production.
Therefore the above mentioned dipole form factor is not realistic for Q² < 0. μ² = 0.71 GeV/c² is not related to a physical pole.
Remark: the form factors are expected to satisfy a dispersion relation like
[tex]G(q^2) = \frac{1}{\pi}\int^\infty_{(2m_\pi)^2}ds \frac{\text{Im}\,G(s)}{s-q^2}[/tex]
  • · Replies 38 ·
  • · Replies 0 ·
