What kind of engineering involves the most physics?
The discussion revolves around which engineering discipline incorporates the most physics, particularly focusing on modern physics. Participants explore various fields of engineering and their relationship with different areas of physics, including applications and theoretical aspects.
  • Some participants suggest that the relevance of physics in engineering varies significantly depending on the specific job or project, with examples from electrical engineering highlighting both programming challenges and quantum mechanics considerations.
  • Others propose that fields like materials science and electrical engineering are closely tied to modern physics, particularly in areas such as semiconductor physics and quantum optics.
  • A participant mentions that applied or engineering physics can encompass similar work to materials science and electrical engineering, depending on the department's focus.
  • There is a suggestion that those interested in modern physics might benefit from taking additional physics courses alongside their engineering studies, especially if their engineering program lacks a strong emphasis on quantum mechanics.
  • Another viewpoint emphasizes that the choice of engineering discipline should align with specific interests in physics, such as condensed matter or optics, and notes that the foundational subjects in mechanical or aerospace engineering include structural mechanics and aerodynamics.
Participants generally agree that the relationship between physics and engineering is complex and context-dependent, with no consensus on a single engineering field that involves the most physics. Multiple competing views on the relevance of different engineering disciplines to physics remain present.
Participants acknowledge that the strength of engineering programs can vary based on the academic staff and institutional focus, which may influence the extent to which physics is integrated into the curriculum.
Individuals considering a career in engineering or physics, students exploring their academic options, and those interested in the application of modern physics in engineering fields may find this discussion relevant.
qpzm77gg
What kind of engineering involves the most physics? It focus on modern physics is the best.
It's not easy to answer this question with regard to broad fields. It generally depends on the specific situation. For instance, an Electrical Engineer could be working on an embedded systems problem that poses more programming/computation challenges than "modern physics" ones. On the other hand, they could be working on how to reduce chip size without allowing quantum tunneling to affect reliability.
Are you looking for an engineering field to study? More specifics about what you're curious about would be helpful in answering your question.
No easy answer. It depends on the job I'm sure. If you like physics go into physics.
If you are interested in doing physics, then as sandplasma says, go into physics.
If you are interested in applying modern physics to design new materials, devices, etc., then the primary options I can think of are:
materials science - much of materials science is effectively applied solid state physics. Some modern materials science academic research involves designing materials starting with quantum mechanics.
electrical engineering - semiconductor physics, materials design, device design. Lasers and quantum optics are sometimes in EE departments.
applied / engineering physics - can do similar work as all of the above, depending upon department.
Of course, here I am assuming by "modern physics" you mean that in the traditional sense where quantum mechanics is important. Cutting edge research in "modern physics" will only be found in physics departments.
If you decide to do engineering and are really interested in these areas, I recommend taking extra courses from the physics department (unless your engineering department is unusually strong with quantum mechanics courses).
best of luck,
jason
It depends on exactly what areas of physics/mechanics you are interested in. For instance if you're interested in condensed matter or optics, a Physics Degree will probably suit you most. In terms of Engineering though, the foundations for Mech or Aero Engineering Degrees are generally structural mechanics, aerodynamics, control theory, propulsion and design. They vary between institution as the strength of the course structure relies on the academic staff in the university faculty. I hope this has helped in answering your question.
The Jericho.
  • · Replies 69 ·
