Continuous function from (0,1) onto [0,1]?
  • Context: Graduate
  • Thread starter Thread starter dumbQuestion
    Continuous Function
The discussion revolves around the existence of continuous functions from the interval (0,1) onto the interval [0,1]. Participants explore various properties of continuous functions, compactness, injectivity, and the implications of these properties in the context of topology.
  • Some participants assert that there cannot be a continuous function from [0,1] onto (0,1) due to the property that the image of a compact set under a continuous function must also be compact.
  • One participant proposes a specific continuous surjection from (0,1) to [0,1] and discusses the nature of proper maps, noting that not all continuous maps have the property that the inverse image of a compact set is compact.
  • Another participant mentions a function that maps (0,1) onto [0,1] but points out that it is not injective, raising the question of whether an injective continuous function can exist between these intervals.
  • There is a discussion about the implications of injectivity and continuity, with one participant arguing that if a function is injective and continuous from an interval of R into R, it must be monotonic.
  • Another participant introduces a theorem regarding continuous bijections between compact and Hausdorff spaces, arguing that (0,1) and [0,1] are not homeomorphic due to differences in compactness and connectedness.
Participants express differing views on the existence of continuous functions from (0,1) onto [0,1], with some arguing against it based on compactness and others providing examples that challenge this notion. The discussion remains unresolved with multiple competing perspectives.
Participants reference various properties of compactness, injectivity, and continuity without reaching a consensus on the implications of these properties for the existence of the desired continuous function.
dumbQuestion
I know that there does not exist a continuos function from [0,1] onto (0,1) because the image of a compact set for a continuous function f must be compact, but isn't it also the case that the inverse image of a compact set must be compact? and a set in R is compact iff its closed and bounded right?
First consider the continuous surjection [itex]f:(0,1) \rightarrow [0,1][/itex] defined as follows:
[tex] f(x) = \left\{<br /> \begin{array}{lcl}<br /> 0 & : & x \in \left(0,\frac{1}{4}\right)\\[0.3em]<br /> 2x-\frac{1}{2} & : & x \in \left[\frac{1}{4},\frac{3}{4}\right]\\[0.3em]<br /> 1 & : & x \in \left(\frac{3}{4},1\right)<br /> \end{array}<br /> \right.[/tex]
Now to answer your other questions ...
Not all continuous maps satisfy this property. Those that do are called 'proper'.
Assuming that you give [itex]\mathbb{R}[/itex] its usual topology and assuming you mean bounded with respect to the Euclidean metric, then yes.
map any set with any topology to a point. This map is continuous and its image is compact.
(1/2) (sin(2pi x)+1) maps (0,1) onto [0,1].
Clearly the problem is that this function is not injective. Same problem with the example by jgens.
Does there exist an injective continuous function mapping (0,1) onto [0,1]? Assume there is, and suppose f(a)=0 and f(b)=1. WLOG assume b>a and let e>0 be small enough so that b+e<1. Since 1 is the max value of f, f(b+e) is strictly between 0 and 1. By the IVT, there exists c between a and b such that f(c)=f(b+e). So f can't be injective after all.
More generally if f is injective and continuous from an interval of R into R, then it must be monotonic and its inverse must be continuous as well.
You can also use a result that a continuous bijection f: X--->Y , between X compact
and Y Hausdorff , is a homeomorphism. And (0,1) and [0,1] are not homeomorphic
for many reasons: [0,1] is compact and (0,1) is not, or (0,1) is 1-connected and
[0,1] is not -- e.g., delete the endpoints of [0,1], and the space remains connected
( I think k-connectedness is also called the Euler number). This also shows there are
no continuous bijections between (0,1) and [0,1) (because [0,1) is not 1-connected;
remove 0, and it remains connected.)
