Infinte number of terms from a sequence in a sub-interval
  • Context: Graduate
  • Thread starter Thread starter led5v
    Sequence Terms
The discussion revolves around a mathematical argument presented in a proof related to sequences within a specified interval. Participants explore the implications of a statement regarding the existence of sub-intervals containing an infinite number of terms from a sequence, examining its validity and the conditions under which it holds.
  • One participant questions the validity of the claim that a sub-interval exists within [a,b] that contains an infinite number of terms from a sequence, citing a constant sequence as a counterexample.
  • Another participant argues that the original statement does not require the terms to be distinct, thus supporting the claim that a constant sequence still contains an infinite number of terms in any interval that includes its constant value.
  • A different participant expresses skepticism about the proof of Theorem 4, particularly regarding the assertion that two distinct values from the sequence must exist in a sub-interval, suggesting that this is not guaranteed.
  • One participant clarifies that the proof involves partitioning the interval into subintervals and asserts that an infinite number of terms from the sequence must fall into at least one of these subintervals.
  • Another participant elaborates on the construction of the sequence and the reasoning behind the assertion that an infinite subset of indices can be found within a specific subinterval.
Participants express differing views on the validity of the original statement regarding the existence of sub-intervals containing infinite terms from a sequence. There is no consensus on the implications of the proof or the conditions under which the claims hold.
Participants note that the proof relies on the nature of the sequence and the properties of the function involved, raising questions about the assumptions made in the argument. The discussion highlights the complexity of the mathematical reasoning and the need for careful consideration of the definitions and conditions applied.
led5v
I have across the following argument, which seems wrong to me, in a larger proof (Theorem 4 on page 9 of the document available at http://www.whitman.edu/mathematics/SeniorProjectArchive/2011/SeniorProject_JonathanWells.pdf). I would appreciate if someone can shed light on why this is true.
The argument is that given a sequence $a_k$ of points in [a,b], we can say that a sub-interval of [a,b] exists such that it is smaller than some value $g<b-a$ and contains an infinite number of terms from $a_k$.
I disagree with the above statement because let's say that the sequence $a_k$ always returns a constant value, say b. Then the above statement doesn't hold.
Yes, it does. It says "an infinite number of terms". It does NOT say "an infinite number of different terms". If your sequence were constant: an= b, then one those intervals will contain b and so contain an "infinite number" (in fact, all) of the terms of the sequence.
Thanks for the clarification and I understand the point. But still I am not very convinced with the proof of Theorem 4 in the cited document above.
The proof utilizes the above statement to conclude that two distinct values of the sequence ($a_k$), say $a_K$ and $a_K′$ would exist in a sub-interval of [a,b] such that $a_K−a_K′$ is greater than some value.
Now, I think the above may not be possible and there is nothing in the original statement that guarantees that two distinct values of the sequence $(a_k)$ would fall in a subinterval of [a,b]. This may happen but we cannot say that it would happen for sure?
Thanks again.
Nah, the proof is fine except for one or two typos. It is not a_k - a_k' that is supposed to be large, but f(a_k)-f(a_k'). The point is this. The interval is partitioned into subintervals. Given the sequence a_k, an infinite number of these must fall into one of the bins (subintervals). That is true for any sequence in the original interval. Then he uses the fact that |f(a_k)| > k for each k to show that it is possible to select indices k and k' such that |f(a_k)|-|f(a_k')| is larger than n/(b-a).
My understanding is that in the original theorem, we want to prove
∃y.∀x.a≤x∧x≤b⇒|fx|≤yIf we contradict this statement, it becomes:
∀y.∃x.(a≤x∧x≤b)∧y<|fx|which can be further simplified to the following form:
∀k.(a≤(g m)∧(g m)≤b)∧m<|(f(g m))
where m is a positive integer and (g_m) represents the sequence (a_k) in my original question.
Now, the main concern that I have is that how can I mathematically prove that two distinct values of (g_m) would occur in a sub-interval of [a,b]. So basically, I don't understand the mathematical reasoning that allows us to reach the following statement that Vargo made from the last equation above.
"Given the sequence a_k, an infinite number of these must fall into one of the bins (subintervals). That is true for any sequence in the original interval. "
The statement is this. We are given an interval I which is partitioned into a finite number of subsets I_1, ..., I_M (which I refer to as bins). Let a_k be any sequence of numbers in I. Then there exists at least one bin, call it I_1, for which there exists an infinite set of indices [itex]K\subset \mathbb{N}[/itex] such that for all k in K, a_k belongs to I_1.
That statement is true on the level of sets, meaning it has nothing to do with the fact that I is an interval and that I_1, ..., I_M are subintervals of a partition. And it has nothing to do with the nature of the sequence a_k. In other words, we can construct any sequence a_k and this fact will be true. In this case the author constructs the sequence a_k by using the hypothesis that f is unbounded on the interval and requiring that
[itex]|f(a_k)|>k[/itex].
Given that construction, let I_1 refer to a subinterval for which there an infinite number of indices k such that a_k belongs to I_1. Let K denote the set of indices for which a_k belongs to I_1. Choose k_1 in K. Now let B >0 be any positive number. K is an infinite subset of the positive integers, so it contains an element k_2 for which
[itex]k_2 > B+ |f(a_{k_1})|[/itex]
Then we conclude that a_{k_2} belongs to the same bin I_1 and
[itex]|f(a_{k_2})| > k_2 > B+ |f(a_{k_1})[/itex]
Now let B = n/(b-a).
  • · Replies 24 ·
  • · Replies 140 ·
15K
