What are these thingies called?
  • Thread starter Thread starter xxgabrielxx
The discussion revolves around the design and construction of a steadicam arm system, focusing on the mechanisms and components that can be used to achieve low friction and noise. Participants explore various bearing options and structural designs, comparing them to existing products like lamp arms.
  • Experimental/applied
  • One participant describes the need for a low-friction pivot mechanism for a steadicam arm, comparing it to a race-car suspension and scissors, and questions the terminology for such components.
  • Another participant suggests that the mechanism resembles a four-bar arm system and mentions the possibility of using a modified lamp arm for lighter loads.
  • A participant clarifies that their steadicam design involves two arms with specific pivoting and spring mechanisms, emphasizing the need for a bearing solution to improve functionality.
  • Discussion includes the identification of a flange mounted bearing as a potential solution, with specific size requirements for internal and external diameters.
  • One participant proposes using nylon flange washers and brass washers as a cost-effective solution after further research.
  • Another participant interprets the original question about bearings and suggests using roller bearings, while expressing confusion about the flange and attachment holes mentioned.
  • A later reply indicates a decision to use regular skateboard bearings, discussing methods to secure them in place and considering alternatives like acrylic tubes and epoxy resin.
Participants express various approaches to the design and components of the steadicam arm, with no consensus on a single solution or terminology. Multiple competing views on bearing types and securing methods remain evident throughout the discussion.
Participants mention specific size requirements for bearings and components, but there are unresolved details regarding the best methods for securing the bearings and ensuring low friction over time.
xxgabrielxx
Sorry for the vague description. (I had to use Google to get the answer to the anti-bot question) I'm making a steadicam system and am wondering how to proceed with the arm. Problem is: I always scavenge rather than buy, so I don't know what anything is called. The arm kind of works like a race-car's suspension, but upside-down. the pivots are joined kinda like the pivot on a pair of scissors, but low friction/noise is very important. The arms are made of aluminium and I'd normally just drill through, cut a little thread on the end of a polished steel bar, push it through and put a nut on either end. (with lubed brass washers between the links of the arm where they would otherwise be in contact with each other. Surely there is a better way. For example, something like a skateboard bearing that can be secured into a hole in the aluminium somehow. Basically something that looks like a skateboard bearing with a flange on one end with some small holes in for attaching it to stuff. What would you call something like that? Does it have a name?
Here's an interesting link for you. It's just a four-spring or four-bar arm mechanism. No special name, really.
Very similar to an Anglepoise Lamp.
What sort of load are you looking to hold with it? They aren't incredibly complex to build, but if the camera is light enough a stock lamp arm or a modified lamp arm (with stiffer springs) might be cheaper.
Edit: Additional reading on balanced-arm lamps: here
The lamp is fairly similar, except the steadicam has two arms, hinged in the middle. Each arm is rectangular and pivoted at each corner, with a spring stretched from one corner to the other. The idea is that, as the arm rises and falls, whatever is at the other end of the arm remains upright. No way a lamp arm could hold the camera, monitor, battery and counterweights.
The design is no problem, all the aluminium parts will be easy to machine, and I'm sure I can get away with just a simple steel rod, threaded on each end, passed through the holes in both pieces, and nutted on the ends. I just think it would work better with some kind of bearing. I found something called a flange mounted bearing, which looks like it would work. But I can't find where to buy them in the appropriate size. Internal diameter would need to be 5 - 10mm. external diameter doesn't matter much...say, 10 - 25mm. The depth of the unit, IE, how far it extends beyond the flange is dictated by the thickness of the aluminium (3mm) It can be less than that, or a little more, but if it's too much more it forces me to use wider arms or a narrower hinge section.
Sorry to double-post. After some Googling, I think the cheapest, easiest solution would be to insert nylon flange washers (1/4 inch bore. (I can cut off any unwanted length easily enough)) And brass washers.
If I understand your question, you're (basically) just looking for an appropriate type of bearing to put into your arms? I think you're looking at a set of four normal roller bearings, but I don't understand what you mean about the flange or 'little holes'.
To get what you're after (quiet, easy to move) I'd drill the initial hole slightly large for your threaded rod, countersink each side, and press in a roller bearing on each end. Your rod goes through that (needs to be a tight fit to work), with a washer between the arms.
Nylon will work as you said, but they do tend to get a bit squeaky over time.
I just decided to go with regular skateboard bearings. The problem was fixing them in place. I'm just going to slide spacers and washers onto the rod to stop the bearings slipping out of their position. I thought about shrink-fitting them, but decided a few bits of acrylic tube is cheaper than a stress-fracture. Maybe I'll use a little epoxy resin, but I really don't see the need now.
17K
10K
  • · Replies 17 ·
17K
11K
