Mass of block given μK and Force?
The discussion revolves around determining the mass of a block being pushed across a horizontal surface, given a specific applied force, coefficient of kinetic friction, and acceleration. The subject area includes concepts from dynamics and friction.
  • Mixed
  • Participants explore the relationship between force, mass, and acceleration using Newton's second law. There are attempts to incorporate the effects of kinetic friction into the calculations. Questions arise regarding the correct setup of equations and the identification of forces acting on the block.
Participants are actively engaging with the problem, with some providing guidance on how to set up equations involving net force and friction. There is an ongoing exploration of the relationships between the forces involved, and multiple interpretations of the setup are being discussed.
Some participants express uncertainty about the normal force and its relation to the mass of the block, which is a key component in calculating the frictional force. The discussion reflects the iterative nature of problem-solving in physics, with adjustments being made to earlier calculations.
Ace.
A student pushes a block with 240 N of force across a horizontal surface with a coefficient of kinetic friction of 0.4. The block accelerates at a rate of 0.88 m/s2. Find the mass of the block.
μK = FK / FN
F=ma
My first attempt was to figure out mass using F=ma
m = f/a
= 240 N / 0.88 m/s2
= 272.7 kg​
but this is not taking into account the kinetic friction...
So what I did was
FK = μK x FN
= 0.4 x (272.7 kg x 9.8 m/s2
= 1069.1 N​
I know I'm doing this wrong and I need to know how to derive at net force to find acceleration
m = f/a
= 240 N / 0.88 m/s2
= 272.7 kg​
To use ƩF = ma you must include all the forces.
So what I did was
FK = μK x FN
= 1069.1 N​
You are using the incorrect answer from your first attempt.
Instead, just call the mass "m" and set up your equation using the net force. Then you can solve for the mass. What's the friction force in terms of "m"?
μK = FK / FN
FN = FK / μK
mg = FK / μK
m = (FK / μK) / g
Like this?
Ace. said:
μK = FK / FN
FN = FK / μK
mg = FK / μK
m = (FK / μK) / g
Like this?
No. (That won't work, since FK is proportional to the mass, so your equation ends up being m = m.)
Use ƩF = ma. First work on the forces. There are two forces acting. What are they?
force applied of 240 N and kinetic friction
I can't find magnitude of kinetic friction because I cannot find Force normal.
Good.
If the mass is "m", what's the weight?
Doc Al said:
Good.If the mass is "m", what's the weight?
weight = 9.8m
Ace. said:
weight = 9.8m
Good. So now you have the normal force. Keep going.
μK = FK / FN
FK = μK × FN
FK= 0.4 x 9.8m
I have 2 unknowns?
Ace. said:
μK = FK / FN
FK = μK × FN
FK= 0.4 x 9.8m
Good.
I have 2 unknowns?
The only unknown is the mass, which is what you are trying to find.
Keep going. What is ƩF?
Fapplied = 0.88m
just guessing here:
Fnet = FA [fwd] + Ff [bwd]
Fnet = FA [fwd] - Ff [fwd]
Fnet = 0.88m - (0.4 x 9.8m)
Ace. said:
Fapplied = 0.88m
The applied force is given as 240 N.
just guessing here:
This is good.
Fix this and then use Fnet = ma.
oh wow my bad...
Fnet = 240 - (0.4 x 9.8m)
= 240 - 2.92m​
Still don't get what I need to do next?
Ace. said:
oh wow my bad...
= 240 - 2.92m​
Apply Newton's 2nd law: Fnet = ma
240 - 2.92m = 0.88m
240 = 0.88m + 2.92m
240 = 3.8m
m = 63 kg
Ace. said:
240 - 2.92m = 0.88m
240 = 0.88m + 2.92m
240 = 3.8m
m = 63 kg
That's the right idea. But I think you made a mistake earlier (probably a typo):
= 240 - 2.92m​
Fix that, resolve your equation, and you'll have the correct mass.
= 240 - 3.92m
240 - 3.92m = 0.88m
240 = 0.88m + 3.92m
240 = 4.8m
m = 50 kg
wohooooooo thanks a lot!:biggrin:
Yay! :approve:
  • · Replies 21 ·
