Understanding the Function and Practical Applications of Voltage Dividers
  • Thread starter Thread starter ricardo7890
    Voltage
The discussion centers on the practical applications and limitations of voltage dividers, specifically their behavior under load conditions. The voltage output (Vout) is calculated using the formula Vout = (V2 / (V2 + V1)) * Vin, but this value can fluctuate when a load is applied, affecting the voltage drop across the resistors. A voltage divider remains useful for providing a stable reference voltage to high impedance loads, such as OP-AMPs, within specified limits. For instance, to achieve a Vout of 5V from a Vin of 10V while maintaining a tolerance of 5% with a 1kΩ load, careful resistor selection is crucial.
  • Understanding of Ohm's Law and basic electrical principles
  • Familiarity with resistor networks and their configurations
  • Knowledge of high impedance loads and their characteristics
  • Basic circuit analysis skills, including voltage calculations
  • Research resistor selection techniques for voltage dividers under load conditions
  • Learn about the impact of load resistance on voltage divider performance
  • Explore the design of voltage dividers for specific applications, such as reference voltages for OP-AMPs
  • Study the use of simulation tools like LTspice to model voltage divider circuits
Electronics students, circuit designers, and engineers working with voltage regulation and signal conditioning in electronic circuits.
ricardo7890
i know this is a very basic question, but there's something i don't understand about voltage dividers.Vout is supposed to be(v2/V2+v1)* V, or the voltage drop across a resistor, but i don't see how this works in practice. When you put a load across the output, this changes the voltage drop of all the resistors in the circuit, so how is a voltage divider useful if you can't have a constant out value.
It's "constant" within limits. Quiz-Question: For Vin=10V and a desired Vout=5V, how would you design the voltage divider if you want to stay within, say, 5% your nominal value when you connect a load of 1kΩ?
Also, they are used when you need to give an input signal to a high impedance load. For example, if you have 5V and need a reference voltage of 3.3V to, say, an OP-AMP, you could use a voltage divider to get those 3.3V.
  • · Replies 78 ·
  • · Replies 16 ·
  • · Replies 32 ·
