What Matrix Transformation Projects a 3D Planar Shape onto the XY Plane?
  • Context: Graduate
  • Thread starter Thread starter weetabixharry
    Subspace
The discussion focuses on transforming a (3 x N) matrix, denoted as A, representing points in 3D space into a (2 x N) matrix that describes the same planar shape on the XY plane. The solution involves using the pseudoinverse of an orthonormal basis derived from the eigendecomposition of AAT, specifically the (3 x 2) matrix E2, which contains the eigenvectors corresponding to the two largest eigenvalues. The transformation is executed by left-multiplying A with the pseudoinverse of E2, resulting in A2D = E2+A, which effectively projects the 3D points onto the XY plane without distortion.
  • Understanding of matrix operations, specifically pseudoinverses.
  • Familiarity with eigendecomposition and eigenvalues.
  • Knowledge of orthonormal bases in linear algebra.
  • Basic concepts of isometric and conformal mappings.
  • Study the process of eigendecomposition in detail, focusing on its applications in dimensionality reduction.
  • Learn about the properties and applications of pseudoinverses in linear transformations.
  • Explore isometric and conformal mappings in higher dimensions.
  • Investigate further into linear algebra concepts, particularly regarding projections and transformations.
Mathematicians, data scientists, and engineers working with multidimensional data analysis, particularly those interested in dimensionality reduction techniques and linear transformations.
weetabixharry
I have a (3 x N) matrix of column rank 2. If each column is treated as a point in 3-space, then connecting the points draws out some planar shape.
What operation can I apply such that this planar shape is transformed onto the x-y axis, so that the shape is exactly the same, but is now described fully by x-y coordinates in a (2 x N) matrix?
I feel like there should be a (2 x 3) matrix that would do this, but I can't figure out what it should be. (I have a hunch that I'm looking for a mapping that is isometric and conformal... some kind of rotation?). Also, I'd like to be able to generalise to higher dimensions.
I think I may have found a solution, but would appreciate any further discussion... since my understanding is rather weak. I basically started thinking about pseudoinverses and figured I wanted a pseudoinverse of something orthonormal, to avoid distorting my shape (?).
Let's call my (3 x N) matrix A. To get an orthonormal basis spanning the (2D) column space, I eigendecompose AAT and take the eigenvectors associated with the 2 largest eigenvalues, denoted by the (3 x 2) matrix E2.
Finally, I left-multiply A by the pseudoinverse of E2:
A2D = E2+A
which seems to give the desired 2D representation.
weetabixharry said:
A2D = E2+A
Of course, this can be simplified as:[tex]\begin{eqnarray*}<br /> \mathbf{A}_{2D} &=&\mathbf{E}_{2}^{+}\mathbf{A} \\<br /> &=&\left( \mathbf{E}_{2}^{T}\mathbf{E}_{2}\right)^{-1} \mathbf{E}_{2}^{T}\mathbf{A%<br /> } \\<br /> &=&\mathbf{E}_{2}^{T}\mathbf{A}<br /> \end{eqnarray*}[/tex]
However, I still don't really have an intuitive idea for why this works. Perhaps I should re-ask the question in Linear Algebra.
