Induction motor - no load speed
The discussion revolves around the behavior of induction motors at no load, specifically whether they run at synchronous speed or slightly below it. Participants explore the concepts of slip, torque production, and the dynamics of rotor speed in relation to synchronous speed.
  • One participant questions if an induction motor runs exactly at synchronous speed under no load or slightly below it.
  • Another participant discusses the implications of rotor speed at synchronous speed, suggesting that torque is zero at that point and speculating on the effects of air friction.
  • A participant asserts that a small difference between synchronous speed and actual speed is necessary for torque production, prompting a request for confirmation of this reasoning.
  • Another participant agrees with the previous point, noting that even at no load, there are small load torques due to factors like wind and bearing friction.
  • One participant corrects an earlier claim about slip, clarifying that slip is zero at synchronous speed and explaining how torque is produced through Lorentz forces in the rotor.
  • A participant inquires about the behavior of induced voltage and current at synchronous speed and how torque changes with rotor speed.
  • Another participant mentions that achieving synchronous speed perfectly would require a frictionless machine and infinite time, and introduces the concept of the induction motor acting as a generator when driven above synchronous speed.
Participants express differing views on the behavior of induction motors at synchronous speed, particularly regarding slip and torque production. There is no consensus on whether the motor runs exactly at synchronous speed or slightly below it, and the discussion remains unresolved.
Participants reference various factors affecting torque and speed, including load torque, air friction, and the mechanics of induced voltage and current, but do not reach a definitive conclusion on these aspects.
MrPacane
Under no load, does an induction motor run exactly at its synchronous speed (i.e. relative field speed) or at a speed that is close to the synchronous speed but slightly less?
Thanks for your time.
What happens when the rotor rotates at synchronous speed (or what does not happen) ?
If you can draw the torque vs. speed curve, or have the equation, you can get the torque at synchronous speed. This does not describe the physics behind what happens but will give you the answer.
Tell us what you think happens and your reasoning, then we can guide you to the right answer. Getting a yes or no answer yield no actual knowledge!
At synchronous speed, the slip is equal to 1 and so the torque is 0. If there's no torque, I think the motor's speed will decrease because of air friction. In order to have torque (and keep the motor running at a constant speed), there needs to be a small difference between the synchronous speed and the actual mechanical speed of the motor.
Am I right?
You certainly are correct mr. Pacane. Even at no-load there will be a small load torque (wind, bearing friction). According to Newtons second law in rotational/cylindric form, steady state (constant speed) is achieved when the load torque and motor torque are equal. A difference in torque gives an (positive-/negative) -acceleration.
(How much this torque and speed difference is in a real case must be individual considered, some motors have large cooling fans connected to the shaft and may give considerably windage loss)
And how is torque produced in an induction motor? Why is there no torque production when slip is equal to 1 as you stated? What happen inside the rotor?
Oh, I just realized I made a mistake! At synchronous speed the slip is zero (slip is equal to 1 at starting because the mechanical speed is zero).
Torque is produced by the Lorentz forces (due to moving charges in a magnetic field). In an induction motor, there are moving charges in the rotor because of the induced voltage. In addition, these moving charges are in a magnetic field produced by the stator.
In other words, first the stator produces a changing magnetic field which induces a voltage in the rotor. Then, Lorentz forces act on the stator because of the induced current running through it and because of the stator's magnetic field.
And how do the fields, induced voltage and current behave at rotor speed equal to synchronous speed?
And how is it that torque changes as the rotor speed changes? What factor in the torque equation changes and why does i change?
Slip is a measure of the relative speed difference between stator and rotor "speed".
Yes. you hace to have a frictionless machine and infinite time (due to the iniertia) to perfectly reach the synchronous speed. That's because the motor puts out less ans less torque as it approaches the speed and zero torque when it gets there.
A more interesting thing happens if you supply torque to the more and drive it OVER synchronous speed. Then, the induction motor behaves as a generator, supplying power back to the line. However, this doesn't work with a simple induction motor being turned. It requires that the line be connected to do this generator trick.
  • · Replies 31 ·
