[At' Pressure] Glass of water held upsidedown
  • Context: Undergrad
  • Thread starter Thread starter BitterX
    Glass Pressure Water
The discussion centers on the physics of an inverted glass of water sealed at the top, demonstrating the principle of atmospheric pressure. When the glass is turned upside down, gravity attempts to create a vacuum at the top, leading to a pressure difference. The air pressure outside the glass exerts a force that counteracts the gravitational pull on the water, preventing it from falling. This phenomenon does not occur when the glass is upright, as gravity keeps the water at the bottom.
  • Understanding of atmospheric pressure and its effects
  • Basic knowledge of gravity and its influence on fluids
  • Familiarity with the concept of vacuum formation
  • Knowledge of fluid dynamics principles
  • Research the principles of fluid dynamics in sealed systems
  • Explore the effects of atmospheric pressure on liquids
  • Learn about vacuum formation and its applications in physics
  • Investigate experiments demonstrating pressure differences in fluids
Physics students, educators, and anyone interested in understanding fluid dynamics and atmospheric pressure phenomena.
BitterX
Hey,
I'm sure you are all familiar with the experiment where you take a glass of water , put a some seal on it and then turn it upside down.
Due to the (atmospheric pressure) - (the air pressure in the glass) exerting a force on the seal upwards greater than the [mg] of the water, the seal stays in place.
here's a demonstration - physicscentral.com
What I don't understand is why there's a pressure difference in the first place.
As far as I know - if I seal the cup then the air pressure is the same there as it is outside (with minor difference - ρgh ) what makes it change when I turn it upside down?
Thanks.
The pressure difference develops because gravity is pulling the mass of the water down in the inverted glass, trying to open up a bubble of vacuum at the top. Air pressure resists the formation of that bubble, pushing the water back up against the force of gravity.
This doesn't happen when the glass is right-side-up, because then gravity is holding the water down in the bottom of the glass.
  • · Replies 32 ·
13K
