Experiment with grounding and EMFs
The discussion revolves around an experiment proposed by a novice participant, Zex, to investigate how grounding affects the electromagnetic field (EMF) generated by an appliance. The scope includes safety concerns, experimental design, and the implications of modifying electrical connections.
  • Zex proposes to modify a 3-pronged power cord by disconnecting the hot lead to measure the magnetic field of an appliance, questioning potential safety hazards and the behavior of electrical current in this setup.
  • Some participants suggest that if the home wiring is correct, disconnecting the hot lead should not pose safety issues, but caution against potential wiring errors that could lead to dangerous situations.
  • One participant emphasizes the importance of using a safety check plug to verify the wiring before proceeding with the experiment.
  • Zex clarifies that the experiment will involve a laptop running on battery power, expressing curiosity about the physical principles involved.
  • Another participant advises consulting a qualified electrician for safety and proper modification of the power cord, highlighting the importance of safety protocols when dealing with electricity.
  • Concerns are raised about the possibility of electrical current traveling through the neutral or ground slots, with some participants noting that while unlikely, it is not impossible.
  • Uncommon events like power surges or lightning strikes are mentioned as potential factors that could affect the experiment.
Participants express a mix of agreement on the safety of the proposed modification under correct wiring conditions, while also highlighting the potential for dangerous wiring errors. There is no consensus on the necessity or value of the experiment itself, as some question its purpose.
Limitations include the assumption that home wiring is correct, the potential for misidentification of wires, and the need for proper safety measures which remain unresolved in the discussion.
ZeroGzex
Hi,
I'd like to do a simple experiment to see how grounding influences the EMF generated by an appliance. I'm a novice at these sorts of things though, and I want to be sure that there aren't any safety concerns which I'm not aware of. In order to do my experiment, I would modify a 3 pronged power cord by bending aside the hot plug and taping it completely over with electrical tape, so that only the neutral and ground plugs connect. I would then plug an appliance into a standard house outlet with this cord and measure how its magnetic field differs from when it is plugged in normally. Would there be any potentially serious hazards in doing this? Also, would it ever be possible for electrical current to travel up through the neutral and/or ground slots of the outlet and into the appliance rather than flowing only in the other direction? Would uncommon events like a power surge or lightning strike have any effect?
Thanks for your replies,
Zex
Welcome to the PF.
As long as your home is wired to code (I'm assuming you are in the US), there should not be any safety issues with disconnecting the Hot lead. Just be sure to disconnect the Hot lead and not the Neutral...!
The results will show that there is no electrification of the appliance if Hot is disconnected. How are you planning on measuring any magnetic fields? What is your overall goal in doing this?
I am not an electrician, this is my understanding:
If your house electricity is wired correctly, there should be no current in and out of the appliance if you disconnect the hot wire. The ground is usually a long rod pounded into the ground soil as ground safety. The neutral is the return wire of a 3 phase hot wire. It is supposed to be grounded to Earth like the ground wire in the power station. Only two hot wire is connected into the house...say call them red and black wire. Each is 110V reference to the neutral wire. But it is 220V across the red and black wire. So in your house, the 220V plug is just the red and black wire, your 110V is either red with neutral ( white) or black with neutral.
So if you cut the hot wire, you have no power...theoretically! BUT, BUT, I have seen houses with wrong wiring, they can accidentally switch the neutral and hot wire around and if you just cut the wire you "think" is the hot wire, you still have the power connected and that is deadly dangerous.
So you need to be careful, use a safety check plug ( one that has LED or lights that show what is safe and what's not) to test the plug before you do this. But I still don't see the point of you doing this as there is no power if everything is correct.
Great. Thanks for the info guys. I'll be measuring the EMF with a meter, and I forgot to mention that I'm planning to do this with a laptop running on battery power. It would indeed be pointless to try it with something that has no battery, though admittedly my knowledge of physics isn't thorough enough to know if there is a point even with a device running on battery power. My rational is simply curiosity. Gaining an understanding of the physical world and all that.
Hello Zex,
Thank you for your interest in experimenting with grounding and EMFs. It is always important to take safety precautions when conducting any type of experiment, especially when dealing with electricity.
Firstly, I would recommend consulting with a qualified electrician before modifying any power cords. They will be able to advise you on the best way to safely modify the cord without causing any potential hazards.
Additionally, I would suggest using proper equipment and following safety protocols when measuring EMFs. This may include using a calibrated EMF meter and wearing appropriate protective gear.
As for the possibility of electrical current traveling up through the neutral and/or ground slots, it is unlikely but not impossible. This is why it is important to consult with a qualified electrician and follow safety protocols.
Uncommon events such as power surges or lightning strikes may have an effect on the experiment, but again, it is important to take safety precautions and consult with a professional before conducting the experiment.
Overall, I would recommend taking proper safety measures and consulting with a qualified electrician before conducting any experiments involving electricity and EMFs.
  • · Replies 78 ·
18K
  • · Replies 79 ·
