Sound Diffraction Explained: What Is It & How Does It Work?
  • Context: High School
  • Thread starter Thread starter einstein1921
    Diffraction Sound
The discussion revolves around the phenomenon of sound diffraction and the ability to hear sounds from a closed office. Participants explore the mechanics of sound propagation through barriers and the factors that influence sound transmission, including diffraction, attenuation, and the sensitivity of human hearing.
  • One participant questions how sound can be heard from a closed office, suggesting that sound diffraction is involved but seeking a detailed explanation.
  • Another participant defines sound diffraction as the bending of sound waves around obstacles and their spreading beyond openings.
  • Some participants note that sound can travel through the thickness of doors and walls, albeit with attenuation, and highlight the logarithmic sensitivity of the human ear to weak sounds.
  • There is a discussion about the mechanical nature of sound, with one participant explaining that sound is a mechanical vibration that can transfer through different media, including air, walls, and doors.
  • Participants discuss how sound energy is transferred from vibrating air to walls and back to the air inside the office, with the efficiency of this transfer depending on the material properties of the door or wall.
  • One participant contrasts sound with light, suggesting that sound can pass through barriers where light cannot.
Participants express varying levels of understanding regarding sound diffraction and the mechanics of sound transmission through barriers. While some points are clarified, there remains uncertainty and debate about the specifics of how sound travels through different materials.
Participants mention attenuation and the efficiency of sound propagation in different materials, but do not resolve the complexities of these interactions or the specific conditions under which sound can be heard through barriers.
This discussion may be of interest to individuals exploring acoustics, sound engineering, or those curious about the physical principles of sound propagation and human hearing.
einstein1921
Hi, my friends. Today, I come up with a question suddenly. It is about Sound diffraction.
why can we hear someone's voice even when he is in a closed office. Many books says that it is because of Sound diffraction. But I can't understand. how does it happen? would you be so kind to explain it in detail? Thank you!
Science news on Phys.org
But the office is closed!
Don't forget that sound can travel through the thickness of doors, and even through some sorts of wall. The sound is attenuated (weakened) but here something else comes into play...
The ear's sensitivity is 'logarithmic'. This implies that it is disproportionately sensitive to very weak sounds. So although the sound intensity might fall by a factor of 1000 as the sound passes through the material of the door, it may still be audible.
why sound can travel through the thickness of doors? please explain it ! Thank you very much!
or you confused sound with light,which can not go after a wall.Sound can,right!
Sound is a mechanical vibration in a medium. It can be transferred to another medium. So ... inside air to wall to outside air. It gets attenuated each time, which is why you don't hear the sound as clearly outside the office as you do inside the office.
EDIT: it can also be reflected off of objects (mostly hard, smooth ones), thus can "go around corners"
Sound travels through solids and liquids as well as gases such as air. In a liquid or solid, the vibrations which make up the sound are passed from one particle to another via the forces which hold the particles together. In many materials (such as steel) the wave energy propagates very efficiently in this way. In softer materials, or materials containing large particles or fibres, much of the energy is scattered or dissipated (making the material slightly hotter), so the sound propagation is inefficient. That's just what you want in the material of a wall or door.
As an extension to what phinds said...
The sound is the vibration of the air. The vibrating air is in contact with the wall, and transfers some of that energy to the wall. Now the wall is vibrating. The vibrating wall transfers some energy to the air inside the office. Now the air inside the office is vibrating, allowing you to hear the noise, even if the office is sealed. If the door is very thin, you hear more through it, because it's easier for the air to vibrate the door. If you make the door very heavy and stiff, it's harder to get the door to vibrate, so less energy is transferred through it. If you make the door infinitely stiff and heavy, then no sound energy passes through it.
14K
  • · Replies 18 ·
  • · Replies 31 ·
