Line Integral: Computing for $\int _1 ^2 V(x)dx$
The discussion focuses on computing the line integral of a vector field V from point (1,1,0) to point (2,2,0) using the identity function as the path. The integral is expressed as ∫_1^2 V(x)dx, where the differential element dℓ is defined as dx 𝑒ₓ + dx 𝑒ᵧ. The key point clarified is that since the function is expressed solely in terms of x, the limits of integration can be directly applied from 1 to 2 without needing additional parametrization. The discussion emphasizes the comfort in using the parametrization x=t, y=t for intuitive understanding.
  • Understanding of vector fields and line integrals
  • Familiarity with differential elements in calculus
  • Knowledge of parametrization techniques in multivariable calculus
  • Basic proficiency in integration methods
  • Study the properties of line integrals in vector calculus
  • Learn about parametrization of curves in multivariable calculus
  • Explore the application of Green's Theorem in line integrals
  • Investigate the relationship between line integrals and path independence
Students and professionals in mathematics, physics, and engineering who are working with vector fields and need to compute line integrals effectively.
mathsciguy
Suppose I have a vector V and I want to compute for the line integral from point (1,1,0) to point (2,2,0) and I take the path of the least distance (one that traces the identity function).
The line integral is of the form:
[tex]\int _a ^b \vec{V} \cdot d\vec{l}[/tex]
Where:
[tex]x=y, \ d\vec{l} =dx \hat{x} + dx \hat{y}[/tex]
Thus the integral can be computed purely in terms of x (can also be y), which looks something like this:
[tex]\int _a ^b V(x)dx[/tex]
What I don't exactly understand is why is it okay to use the limits like this:
[tex]\int _1 ^2 V(x)dx[/tex]
Why can we use the limits from 1 to 2 if we express the line integral in terms purely of x. I have a very vague idea of why it is, but I'd rather take it from people who actually know this to explain this to me. Thanks.
If I understand you correctly, the function you end up integrating is only in terms of ##x##, and therefore you don't need to parametrize it (or you can look at it by saying you are using ##x## as your parameter). Either way, because your function is dependent only on ##x##, all you have to do is integrate along the x-axis, which is from 1 to 2.
Actually, I've found out that to 'parametrize' the variables into x=t, y=t is a more comforting method to do it. At least intuitively, I see it as tracing the path of integration when we set the x and y variables into that parametric equation.
Edit: Yes, I didn't see it, but I was using x as the parameter. Thanks.
  • · Replies 27 ·
