Waveforms compatible with transmitting channel?
  • Context: Undergrad
  • Thread starter Thread starter zakee.fancy
    Channel Waveforms
Waveforms must be compatible with transmitting channels to ensure effective communication. Transmission mediums, such as coaxial cables and waveguides, have specific cutoff frequencies that limit the range of frequencies that can be transmitted. For instance, coaxial cables exhibit significant loss at higher frequencies, while waveguides are ineffective for lower frequency electromagnetic signals. Understanding these limitations is crucial for optimizing waveform transmission.
  • Understanding of transmission mediums, specifically coaxial cables and waveguides
  • Knowledge of frequency response and cutoff frequencies
  • Familiarity with electromagnetic signal propagation
  • Basic concepts of waveform characteristics
  • Research the frequency response characteristics of coaxial cables
  • Learn about waveguide design and its limitations for different frequencies
  • Explore the impact of lossy transmission mediums on signal integrity
  • Investigate advanced waveform modulation techniques for efficient transmission
Engineers, telecommunications professionals, and anyone involved in signal transmission and waveform design will benefit from this discussion.
zakee.fancy
why waveforms should be compatible with transmitting channel?
What if i send a random wave without having much information about it?
Could you please give more information about your question, and preferably a few examples about the "channels" that you are asking about.
Without knowing more, I would offer that some transmission means have cutoff frequencies. So you may be limited in what frequencies you use. Coax cable is lossy at higher frequencies for example. And waveguides do not pass lower frequency EM signals...
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 29 ·
