Solar cells in parallel and series
The discussion revolves around measuring the performance of individual solar cells within a manually constructed solar panel, specifically focusing on how to evaluate their degradation after being subjected to damage. Participants explore methods for connecting a multimeter to the cells, the feasibility of severing connections, and the potential for creating IV curves to assess performance.
  • Exploratory, Technical explanation, Experimental/applied
  • One participant describes an experiment measuring the performance of solar cells on a panel with 20 cells arranged in 4 parallel strings of 5 series cells each, questioning the best method to connect a multimeter for individual cell testing.
  • Another participant notes that accessing individual cells in typical solar panels is difficult due to sealing compounds, suggesting that attempts to connect to individual cells could damage them.
  • A participant clarifies that their solar panel design allows for direct access to the positive and negative leads of each cell, making multimeter connections feasible.
  • One suggestion is to cover all but one string of cells and test them one at a time, using an ammeter, voltmeter, and potentiometer to graph the IV curve, while also measuring short-circuit current and open-circuit voltage.
  • Another participant recommends severing electrical connections between cells to avoid interference during testing, and suggests using different resistances to create a rudimentary IV curve for performance evaluation.
  • There is a mention of the importance of measuring the intensity of the light source to ensure consistent conditions for testing the cells.
Participants express differing views on the feasibility of accessing individual cells and the necessity of severing connections for accurate measurements. There is no consensus on the best method for evaluating the cells' performance, as multiple approaches are proposed.
Participants acknowledge limitations in their methods, such as the inability to measure light intensity accurately and the potential for damage when accessing individual cells. The discussion reflects varying assumptions about the construction of the solar panel and the implications for testing.
TheFerruccio
Hi,
I am conducting an experiment whereby I have to measure the individual performance (on a per-cell basis) of solar cells on a solar panel. The panel has 20 cells, which are 4 strings in parallel of 5 cells in series each. The entire panel has a +V and chassis GND wire that I can open or close.
I have the solar panel positioned in front of a high power LED to ensure that it gets roughly the same amount of light. (I am not looking for raw cell performance, but, rather, before/after tests).
What is the best way to hook up a multimeter to an individual cell so I can figure out how much it has degraded? I am hitting these solar cells with things, and seeing how they perform after cracked.
Do I need to sever the electrical connections between them so the results are not skewed?
The attached picture shows what I am doing.
I am not even sure what the best way of evaluating the health is. Should I be measuring with different resistances so I can get some kind of rudimentary IV curve? I do not know the intensity of the controlled light setup and I have no way of finding out what the intensity is, either. All I know is that it is the same. I am thinking that all I can do is get a good idea for how the voltage/current changes before/after damage.
Hi there :0
getting at individual cells is pretty much impossible for most solar panels as the individual cells are buried in a sealing compund ... epoxy, polyeurathane etc and any attempt to get at the electrical connections of am individual cell is likely to damage it beyond usefullness
Dave
What I have is not like most solar panels. The cells are individually placed on a PCB in a way that the + and - leads are fully visible and accessible to a multimeter. This solar panel was manually constructed, and is of the form shown in the diagram. Assume that all the wires in the diagram are fully accessible to a multimeter.
Your goal seems to be to test each cell individually before and after damage. If that's the case, and you can't somehow disassemble the panel into its individual cells, I think I'd cover up all but one string and work on one string at a time. Use an ampmeter, a voltmeter, and a potmeter to graph the IV curve. Make sure you include the short-circuit current and open-circuit voltage in your measurement range. Short out a cell with a wire once it's damaged, before moving on to the next. What color is your LED light source?
I would recommend measuring the individual performance of each solar cell before and after the damage using a multimeter. This can be done by connecting the positive lead of the multimeter to the positive terminal of the cell and the negative lead to the negative terminal. This will give you a reading of the voltage and current produced by the cell. Repeat this process for each cell and record the results.
To ensure accurate results, it would be best to sever the electrical connections between the cells before testing. This will prevent any interference from neighboring cells and give you a more accurate measurement of the individual cell's performance.
In terms of evaluating the health of the cells, you can use different resistances to create a rudimentary IV curve, which will give you a better understanding of how the voltage and current change with different levels of resistance. This can help you identify any changes in the cell's performance after damage.
It would also be helpful to measure the intensity of the controlled light setup using a light meter. This will give you a better understanding of the amount of light the cells are receiving and can help you compare the results between cells.
Overall, the best approach would be to measure the individual performance of each cell using a multimeter, sever the electrical connections between cells, and use different resistances to create an IV curve. This will give you a comprehensive understanding of the health of each cell and how it is affected by damage.
  • · Replies 31 ·
