Redshift / blueshift of light in a gravity well
The discussion revolves around the effects of gravity on the redshift and blueshift of light as it interacts with gravitational fields, particularly in the context of gravity assist maneuvers used by spacecraft. Participants explore whether light experiences a similar "jolt" as it moves through gravity wells, and how this might relate to concepts like the Integrated Sachs-Wolfe Effect.
  • Some participants note that light is blueshifted when approaching a star and redshifted when leaving, questioning whether this shift cancels out during gravity assists.
  • One participant suggests that light may not take momentum from a moving star or planet, raising the idea of whether reflection off a moving object could resemble a gravity assist.
  • Another participant introduces the concept of the Integrated Sachs-Wolfe Effect, indicating that light can experience a net shift due to changes in gravitational potential wells over large scales.
  • There is a discussion about the "slingshot effect" and whether it applies to light, with some suggesting that the deflection is minimal unless atmospheric interactions are involved.
  • One participant proposes a hypothetical scenario involving a photon rocket and how energy transfer might occur during a gravity assist, questioning the implications for the energy of photons involved.
  • Some participants discuss the analogy of light bouncing off a planet's atmosphere and whether this would produce a redshift or blueshift similar to other objects.
Participants express various viewpoints on the interaction of light with gravity wells and the mechanics of redshift and blueshift, with no clear consensus reached on whether light experiences a net change in momentum or energy during these interactions.
Some claims depend on specific trajectories and the relative motion of objects, and the discussion includes hypothetical scenarios that may not have been fully resolved or agreed upon.
Lino
I appreciate that as light approaches (say) a star, the light is blueshifted by gravity, and that as it leaves the area of the star, the light is redshifted as it climbs out of the gravity well. However, given that spacecraft execute gravity assist manoeuvres to increase / reduce speed, does light also get a positive or negative “jolt” such that the blue and red shift does not cancel exactly?
(I appreciate that, if it happens, the magnitude the jolt would depend on the specific trajectory.)
Regards,
Noel.
Space news on Phys.org
A gravity assist happens because the gravitational source, usually a planet, is moving. The spacecraft steals a tiny bit of the planets orbital momentum. Stars move also, but I am not sure if light can take momentum away from the planet or star. I wonder, would reflection off a moving object be similar to a gravity assist? I only bring that up because of the ball bouncing off the train picture they use in the wiki article below.
See here: http://en.wikipedia.org/wiki/Gravity_assist
Thanks Drakkith. (In relation to the gravity assist, I appreciate that the numbers involved are very small, but) Am I right in saying that the spacecraft changes velocity while the planet moves to a different orbit?
Do you know if the same would apply to objects with peculiar velocities (i.e. assuming that the various vectors matched-up, could I use a slingshot around a rogue planet / star, that is not orbiting … anything, to obtain the boost / brake – I assume that it does and that there is a negligible impact on the trajectory of the rogue)?
Regards,
*Noel.
If it is moving relative to something else you can.
Thanks Drakkith.
Regards,
Noel.
Regards,
Noel.
If light aproaches a matter-antimatter bomb, which explodes when the light has blueshifted, then the light keeps half of the blueshift.
If light aproaches an object, which is pulled away at nearly speed of light, when the light has blueshifted, then the light does half of the work of separating the light and the object, and loses half of the blueshift.
If we ask a large object, that does not do any sudden movements, about the speed change of a passing small object, the large object says: "the small object approched me at some speed, and left at that same speed".
er, that is nonsense.
Regards,
Noel.
If the gravitational potential well changes as the light ray passes through it, then yes, the light can pick up a total redshift or blueshift. This actually happens at very large scales, as dark energy makes it so that the gravitational potential wells for very large galaxy clusters get shallower over time, so that the light rays going into them don't redshift quite as much on the way out as they blueshifted on the way in. Underdense regions of the universe have a similar but opposite effect.
This is known as the Integrated Sachs-Wolfe Effect.
Thanks Chalnoth. That (Sachs-Wolfe effect) is actually on my list of things to get a better understanding of!
Regards,
Noel.
Also the plain old slingshot effect works with light. The deflection is small though, unless we use the athmosphere of the planet to deflect the light.
Thanks Jartsa. I assume that the "atmosphere" proportion is as a result of a different process. Is that correct?
Regards,
Noel.
A "photon rocket" using "powered slingshot effect":
The rocket approaches a planet, at the nearest point it fires its engines. Because the speed of the rocket is high, the increase of kinetic energy is large, this is matched by a large redshift of the propellant (photons).
Let's say the spacecraft carries photons as a cargo. These photons become blueshifted. If the planet lost kinetic energy in this process, then part of that energy went into the cargo photons.
EDIT: Oh yes, I could avoid the silly "cargo photons" by saying that the "photon rocket" uses the "powered slingshot effect" in order to lose a lot of kinetic energy. The propellant (photons) gains all this energy, assuming the planet's energy did not change.
Regards,
Noel.
Well, looks like same process to me:
A: Light experiences an elastic collision with the athmosphere of a planet.
B: Light experiences an elastic collision with the gravity field of a planet.
Although there is a slight difference in the details of A and B.
jartsa said:
... A: Light experiences an elastic collision with the athmosphere of a planet ...
Ah! Just like craft / body bouncing off the upper atmosphere?
Regards,
Noel.
Regards,
Noel.
Yes.
I was thinking about this and I can see how the "bounce" would produce a change in velocity for objects traveling at less than c, but would it produce a red / blue shift in light as well?
Regards,
Noel.
Regards,
Noel.
Sure it produces. All people say that policeman's radar measures the Doppler shift of microwaves that bounce back from an approaching car.
Most people say that a scientist's Doppler radar measures the Doppler shift of microwaves that bounce back from an approaching black hole. (black holes scatter some microwaves back)
I say that the microwaves experience compression when slowing down while entering the gravity field, and expansion when speeding up while leaving the gravity field, and compression and expansion are unequal when the gravity field is moving.
Understood. Thanks Jartsa.
Regards,
Noel.
  • · Replies 39 ·
  • · Replies 33 ·
  • · Replies 28 ·
  • · Replies 30 ·
  • · Replies 38 ·
11K
