What should be the influence of the imaginary part on a complex number?
The discussion centers on the influence of the imaginary part of a complex number in simulation models, specifically when modeling stiffness and damping coefficients of materials. The user, Ila, observes that varying the real part (stiffness) and the imaginary part (damping) yields identical results, raising questions about expected behavior. Participants clarify that the imaginary part represents phase and the real part represents amplitude in the context of vibrations, suggesting that the simulation may not be sensitive enough to distinguish between these parameters.
  • Understanding of complex numbers and their representation as z=a+ib
  • Knowledge of stiffness and damping coefficients in material science
  • Familiarity with simulation modeling techniques
  • Basic concepts of vibrations and their mathematical representation
  • Explore the mathematical properties of complex numbers in simulations
  • Research the relationship between stiffness and damping in material behavior
  • Investigate advanced simulation techniques for differentiating parameters
  • Learn about the impact of phase and amplitude in vibration analysis
Engineers, material scientists, and simulation modelers who are working with complex numbers in the context of material properties and vibration analysis.
pseudorandom
Hi,
I am asking because I am running a simulation model where the input is a complex number; say z=a+ib
Now the problem is that I get the same result when I put a=0 and give some high value to b, as when I do the vice-versa.
Should this behaviour be expected?
I look forward to a reply. Thank you in advance.
Regards,
Ila
I'm no expert, but I'm pretty sure your question is too general to be given a meaningful reply. What sort of simulation is it? What, specifically, is the input modeling? As far as I understand, the imaginary part of a complex number refers to a quantity of rotation around the complex plane, where the real part refers to the radius of said rotation. Though even this description is likely insufficient.
Hey! Thanks for your reply. The input is the stiffness and damping coefficients of a material. And youre right; the stiffness corresponds to the amplitude and damping to the phase of the resulting vibrations.
I would expect different results if I change the stiffness and the damping of a material separately. But here i get the same result.
  • · Replies 16 ·
  • · Replies 36 ·
