If F(x,y)=<M(x,y),N(x,y)> is a vector field on the plane?
The discussion centers on the vector field F(x,y) = and its components M(x,y) and N(x,y), which are differentiable functions. It is established that the vector field cannot be conservative because the condition (∂N(x,y)/∂x) – (∂M(x,y)/∂y) = 1-x indicates a non-zero curl. The integral ∫F.dr over the curve C defined by x^2+y^2=1 can be computed using Green's Theorem, which relates the line integral around a simple closed curve to a double integral over the region it encloses.
  • Understanding of vector fields and their components
  • Knowledge of partial derivatives and their implications
  • Familiarity with Green's Theorem
  • Basic skills in line integrals and their calculations
  • Study Green's Theorem and its applications in vector calculus
  • Learn how to compute line integrals in the context of vector fields
  • Explore the conditions for a vector field to be conservative
  • Investigate examples of non-conservative vector fields and their properties
Students and professionals in mathematics, particularly those studying vector calculus, as well as engineers and physicists dealing with vector fields and line integrals.
sarahkelly
its components M(x,y) and N(x,y) are differentiable functions that satisfy (∂N(x,y)/∂x) – (∂M(x,y)/∂y) = 1-x.
a. is it possible for the vector field to be conservative? Explain.
b. Let C be x^2+y^2=1 centered at the origin traced counter clockwise. compute the integral ∫F.dr
Since, the partial derivatives don't equal each other, they're not conservative. But how should I go about calculating this line integral?
Well, first before we help you, you should say what you've gotten so far. Though based off the information given, I'll guess you know about Green's Theorem, in which case this is a fairly easy problem.
a. is it possible for the vector field to be conservative? Explain.b. Let C be x^2+y^2=1 centered at the origin traced counter clockwise. compute the integral ∫F.dr
You are not give F but you are given (∂N(x,y)/∂x) – (∂M(x,y)/∂y) = 1-x. Use Green's theorem.
  • · Replies 22 ·
