Compute Tricky Limit Using Taylor Series and De L'hopital's Theorem
The discussion revolves around computing the limit \(\lim_{x\to +\infty} x \left((1+\frac{1}{x})^{x} - e \right)\), which involves concepts from calculus, specifically limits and Taylor series expansions.
  • Participants explore using Taylor series and L'Hôpital's theorem to evaluate the limit. There are questions about the appropriate point for the Taylor expansion and the application of derivatives. Some participants suggest rewriting the limit in terms of a new variable to simplify the analysis.
The discussion includes various attempts to apply Taylor series and L'Hôpital's rule, with some participants expressing confusion over the correct application of these methods. There are indications of productive direction as some participants refine their approaches and clarify their reasoning.
Some participants express uncertainty about the assumptions made in their calculations, particularly regarding the behavior of the limit as \(x\) approaches infinity. There are also references to the need for careful differentiation and the potential for typos in the mathematical expressions presented.
Felafel
compute the following limit:
## \displaystyle{\lim_{x\to +\infty} x \left((1+\frac{1}{x})^{x} - e \right)} ##
i wanted to use the taylor expansion, but didn't know what ##x_0## would be correct, as the x goes to ## \infty##.
also, i tried to use de l'hopital's theorem but it wouldn't work.
how can i do that?
Is it supposed to be e or e^x?
Surely e; this limit would quantify, to first order, how rapidly [itex](1 + 1/x)^x[/itex] converges to its limit e.
Try rewriting the limit in terms of z=1/x.
[tex]x\left(\left(1 + \frac1x\right)^x - e\right) = x\left(\exp\left(x\ln \left(1 + \frac1x\right)\right) - e\right)[/tex]
At this point, one can proceed to substitute the Maclaurin series for [itex]\ln(1 + t)[/itex] with [itex]t = x^{-1}[/itex] (we want the limit as [itex]x \to \infty[/itex], so we can assume [itex]0 < t = x^{-1} < 1[/itex]) to get
[tex]x\ln\left(1 + \frac1x\right) = \sum_{n=0}^{\infty} \frac{(-1)^n}{(n+1)x^n}[/tex]
and then substitute that into the series for [itex]\exp(x)[/itex] to get
[tex]\exp\left(x\ln\left(1 + \frac1x\right)\right) = <br /> \sum_{k=0}^{\infty} \frac1{k!} \left(\sum_{n=0}^{\infty} \frac{(-1)^n}{(n+1)x^n}\right)^k = \sum_{m=0}^{\infty} \frac{a_m}{x^m}[/tex]
(everything here is absolutely convergent, so I can add terms in whatever order I want) so that
[tex]x\left(\left(1 + \frac1x\right)^x - e\right) = \left(\sum_{m=0}^{\infty} \frac{a_m}{x^{m-1}} - ex\right) = x(a_0 - e) + a_1 + \sum_{m=2}^{\infty} \frac{a_m}{x^{m-1}}[/tex]
It's clear that the series on the right tends to 0 as [itex]x \to \infty[/itex], so all you need to work out to determine the limit (if any) is [itex]a_0[/itex] and [itex]a_1[/itex]. (You'll need to consider, for each [itex]k[/itex], what the coefficients of [itex]x^0[/itex] and [itex]x^{-1}[/itex] are and add them all together. Actually you can truncate the inner series after [itex]n = 1[/itex], because including [itex]n \geq 2[/itex] doesn't give you any more terms of order [itex]x^0[/itex] and [itex]x^{-1}[/itex] then you already have.
But that is a brute-force method and I'm sure there's a more elegant solution.
how can i do that?
L'Hôpital's rule works just fine.
[itex]\displaystyle \frac{d}{dx}\left(f(x)\right)^x=\frac{d}{dx}e^{x \ln(f(x))}[/itex]
[itex]\displaystyle =\left(\ln(f(x))+\frac{x}{f(x)}\right)e^{x \ln(f(x))}[/itex]
[itex]\displaystyle =\left(\ln(f(x))+\frac{xf'(x)}{f(x)} \right)\left(f(x)\right)^x[/itex]
Fixed in Edit.
[itex]\displaystyle =\left(\ln(f(x))+\frac{x}{f(x)} \right)\left(f(x)\right)^x[/itex]
You forgot to apply the chain rule when differentiating ln(f(x)).
vela said:
you forgot to apply the chain rule when differentiating ln(f(x)).
DUH !
Thank you vela !
what if i use the taylor series for ##x_0=1##?
it should become:
##\displaystyle \lim_{x \to \infty}\ x [(2+(x-1)log(4)-1+o((x-1)^2)-e] = \infty * \infty = \infty ##
is it correct?
Nope
..maybe it was just de l'hospital then, does this look ok to you?
##\displaystyle \lim{x \to \infty}\ \frac{1}{\frac{1}{x}} ((1+ \frac{1}{x})^x-e) = \frac{0}{0}##
using de l'hopital
##\displaystyle \lim{x \to \infty}\ \frac{1}{\frac{-1}{x^2}} (x(1+\frac{1}{x})^{x-1}*\frac{-1}{x^2}##
which is
## = \infty * \frac{e}{1+0} = \infty ##
You didn't differentiate correctly. See post #6. You should get a finite answer.
i can't solve it with derivatives. i eep using de l'hopital but it gets worse and worse.
i thought i could split it into:
##\displaystyle \lim x \to \infty\ x(1+1/x)^x - \displaystyle \lim x \to \infty\ xe ##
and use taylor series for x=0 of the second part, which becomes:
##x*\displaystyle\sum\limits_{k=0}^n \frac{1}{k!} ##
however, i can't figure out the series of the first part
You don't want to use a Taylor series about x=0. You want to be able to neglect high-order terms which you can't because the limit is for ##x \to \infty##.
Why don't you try my suggestion of rewriting the limit in terms of z=1/x? It'll make applying L'Hopital's more straightforward, and because the limit will be for ##z \to 0##, you can use a Taylor series about ##z=0## if necessary.
okay, I think I've solved it:
##\lim_{y \to 0}\frac{(1+y)^{\frac{1}{y}}-e}{y}=\lim_{y \to 0} \frac{e^{\frac{1}{y}log(1+y)}-e}{y}##
I find the Maclaurin extension for log(1+y), stopping at the third power
##log(1+y)=y-\frac{y^2}{2}+\frac{y^3}{3}##
##\displaystyle{\lim_{y \to 0} \frac{e^{1-\frac{y}{2}-\frac{y^2}{3}}-e }{y}}(=\frac{0}{0})##
## \stackrel{\text{H}}{=} \displaystyle{ \lim_{y \to 0} (-\frac{1}{2}+2\frac{y}{3})e^{1-\frac{y}{2}+\frac{y^2}{2}}}##
##=-\frac{e}{2}##
should be ok now
Yes, that's ok now. There's a couple of what are obviously just typos. But nothing important.
  • · Replies 27 ·
