Question about the application of the chain rule
The discussion revolves around the application of the chain rule in calculus, specifically in the context of determining the rate of change of the radius of a balloon as air is pumped into it. Participants explore the relationships between volume, radius, and time, and seek to understand the reasoning behind the use of derivatives in this scenario.
  • One participant expresses confusion about the inclusion of dr/dt in the equation, questioning its origin and how it relates to the other derivatives.
  • Another participant attempts to clarify the relationship between the derivatives, suggesting that they can be treated like fractions for conceptual understanding, but acknowledges that this is not mathematically rigorous.
  • A participant reiterates the importance of understanding the chain rule, proposing that it describes how the rate of change of one variable can be expressed in terms of the rates of change of other related variables.
  • There is a discussion about the validity of treating derivatives as fractions, with some participants agreeing that this can be a useful simplification while others caution against it.
  • One participant provides an example of the chain rule using a different function to illustrate the concept, suggesting that the original problem follows a similar structure.
  • Another participant explains the chain rule in terms of functions and their rates of change, emphasizing the multiplicative relationship between them.
Participants express varying levels of understanding regarding the chain rule and its application. There is no consensus on the best way to conceptualize the relationship between the derivatives, and some participants remain uncertain about the legitimacy of treating them as fractions.
Some participants highlight the limitations of their explanations, noting that while the fraction analogy can aid in understanding, it may not hold up under deeper scrutiny. There is also mention of a proof of the chain rule that is not typically encountered at the high school level.
This discussion may be useful for students learning calculus, particularly those grappling with the chain rule and its applications in related rates problems.
Astrum
Air is being pumped into a spherical balloon at a rate of 5 cm3/min. Determine the rate at which the radius of the balloon is increasing when the diameter of the balloon is 20 cm.
So, to solve, I know HOW to do it, I just don't know WHY it's right.
[itex]\frac{dv}{dr}=4pi r^{2}[/itex]
[itex]\frac{dv}{dt}=5cm^{3}/s[/itex]
= [itex]\frac{dv}{dt}=4pir^{2}\frac{dr}{dt}[/itex]
Solve for dr/dt
Where does dr/dt come from? I can't understand how it makes sense. It seems as if we're just pulling it out of the air.
##\frac{dv}{dt} = \frac{dv}{dr}\frac{dr}{dt} = 4 \pi r^2 \, \frac{dr}{dt}##
Specifically what part are you having trouble with?
I don't understand why we throw [itex]\frac{dr}{dt}[/itex] in there. It confuses me. the radius is a function of time, but why is it that we can do - [itex]\frac{dv}{dt}=\frac{dv}{dr}\frac{dr}{dt}[/itex]?
It just seems like "Well, we need to find [itex]\frac{dr}{dt}[/itex], so let's just throw it in there and it'll all work out.
I guess I don't understand how all these derivatives relate to each other.
Well, you can look at the derivatives like fractions. Look at: ##\frac{dv}{dr} \cdot \frac{dr}{dt}##. Notice that this quantity has a ##dr## in both the numerator and the denominator so they cancel out, meaning ##\frac{dv}{dr} \cdot \frac{dr}{dt} = \frac{dv}{1} \cdot \frac{1}{dt} = \frac{dv}{dt}##
It is important to note that this isn't actually legitimate. Even though the Leibniz notation for derivatives we are using makes them look like fractions, they aren't actually fractions and can't be treated as such. Often for explaining simple ideas you can act like they are fractions to get the point across, but it's important to realize they actually aren't.
I noticed this about the canceling out.
[itex]\frac{dv}{dt}[/itex], here, the volume is a function of time. Change in volume with respect to time.
[itex]\frac{dv}{dr}[/itex], here volume is a function of the radius. Change in volume with respect to radius.
[itex]\frac{dr}{dt}[/itex], here radius is a function of time. Change in radius with respect to time?
I really don't understand why [itex]\frac{dv}{dr}\frac{dr}{dr}=\frac{dv}{dt}[/itex]
If it's not because they're fractions, what's the reason? Take the derivative of volume with respect to radius, multiply by derivative of radius with respect to time, which gives you change in volume with respect to time.
I'm tempted to say "because that's exactly what the chain rule says, expressed in that notation", but I don't think that's actually useful. So I'll ask you directly, what do you know about the chain rule? (Write it down as if you were teaching someone.)
To be honest, if I was trying to show someone the chain rule, I'd do an example.
[itex]\frac{dx}{du}\frac{du}{dx}=\frac{dy}{dx}[/itex]
[itex]f(x)=sin(x+1)[/itex]
[itex]u=x+1[/itex]
[itex]\frac{du}{dx}=1[/itex]
= [itex]f(u)=sin(u); \frac{dy}{du}=cos(u)[/itex]
[itex]\frac{dy}{dx}=cos(x+1)[/itex]
So, in words. If y is a function of u, and u is a function of x, [itex]\frac{dx}{du}\frac{du}{dx}=\frac{dy}{dx}[/itex]
So, in the original problem, [itex]\frac{dv}{dt}[/itex] is a function of [itex]\frac{dv}{dr}[/itex] which is a function of [itex]\frac{dr}{dt}[/itex]?
The idea of the chain rule is that if you have a function f(p) where p is a function of x: p(x), and you want to find the rate at which f changes with respect to a change in x, you take the rate at which f changes with respect to p and multiply that by the rate at which p changes with regards to x.
There is a proof of this but at the high school level you don't encounter it. As I said, the fraction explanation works as long as you don't look too deep and if you do look deep then you can proof it rigorously.
  • · Replies 36 ·
