Simple and quick question on rotational motions
  • Thread starter Thread starter SecretSnow
    Rotational
The discussion revolves around a particle rotating around an axis with constant angular acceleration, which breaks loose and moves tangentially and horizontally. Participants are examining the implications of tangential acceleration in this context.
  • Participants explore the forces acting on the particle after it breaks loose, questioning the role of tangential acceleration and its relevance once the particle is no longer attached to the rotating system.
There is an active exploration of the concepts of tangential and radial acceleration, with some participants suggesting that tangential acceleration is relevant only while the particle is attached to the rotating wheel. Others are clarifying the nature of forces acting on the particle post-separation.
Participants are discussing the definitions and implications of tangential and radial accelerations, and how these concepts apply before and after the particle loses contact with the rotating system. There is a focus on the transition from circular motion to projectile motion.
SecretSnow
Hi guys, if a particle that is rotating around a axis at a constant angular acceleration, and at the highest point, it broke loose and flies off tangently and horizontally into the air, does it have a tangential acceleration of r*angular acceleration alpha? Please help! This is found in University physics textbook qns 9.63 and the answer never includes the tangential acceleration although I think it should!
After the particle breaks loose, what forces are acting on it?
I think it's weight...and nothing else? Oh! I see... So the tangential acceleration serves its purpose only when it's rotating?
Yes.
"serves its purpose" is a little bit unclear. The particle, while attached to the accelerating wheel, experiences tangential acceleration and radial acceleration.
lewando said:
Yes.
Serves it purposes meaning speeding up the tangential velocity. So it only still speeds up the tangential velocity while spinning right? Thanks a lot!
Sorry, words are failing me lately. I would say that while the wheel is experiencing angular acceleration, the particle is experiencing tangential acceleration, with a resulting change in tangential velocity (could be speeding up or slowing down based on the direction of angular acceleration), as long as it is attached.
Any time a particle moves along a curved path we can speak about tangential and radial acceleration.
The tangential acceleration is along the tangent of the path, and its magnitude is at=dv/dt, derivative of the speed with respect to time. The radial acceleration is normal to the tangent and points toward the centre of the curvature of the path; the magnitude is v2/R where R is the radius of curvature.
When the particle loses contact, it experiences a different force as before: gravity instead of the resultant force which forced it move along the circle with constant angular acceleration. The acceleration is proportional to the force: the force changes so does the acceleration. At the same time the velocity stays the same as just before loosing the contact, it is horizontal.
As the force is vertical and the particle moves horizontally at the first instant after breaking loose, there is no tangential force acting on it so the tangential acceleration is zero.
Later on, the particle moves like a projectile along a parabola. With respect to that parabola, gravity has both tangential and radial components, so there will be both radial and tangential components of the acceleration.
ehild
