Uniqueness Theorem: Qualitative Example of 1st Order Linear DE
The uniqueness theorem for first order linear differential equations states that if the function f(x, y) is continuous and Lipschitz in y around the point (x_0, y_0), then the equation dy/dx = f(x, y) with the initial condition y(x_0) = y_0 has a unique solution in a neighborhood of x_0. Changing the initial conditions results in different solutions, but the theorem guarantees a unique solution for specified initial conditions. This concept can be extended to higher order equations by transforming them into a system of first order equations.
  • Understanding of first order linear differential equations
  • Familiarity with the concept of Lipschitz continuity
  • Knowledge of initial value problems in differential equations
  • Ability to transform higher order differential equations into first order systems
  • Study the implications of the existence and uniqueness theorem in various contexts
  • Learn about Lipschitz continuity and its applications in differential equations
  • Explore methods for transforming higher order differential equations into first order systems
  • Investigate examples of initial value problems and their unique solutions
Mathematicians, students studying differential equations, educators teaching calculus, and anyone interested in the theoretical foundations of differential equations and their applications.
JaredPM
Can someone give me a qualitative example of the uniqueness theorem of a first order linear differential equation? I have read the definition, but I am not 100% positive of what it means in regards to an initial value problem.
Im confused about what a unique solution is when/if you change the initial value. Would it not have many different solutions?
Yes, of course if you change the initial conditions, you will have different solutions! What the "existence and uniqueness" theorem for initial value problems says is that a given (well behaved) differential equation, with specific initial conditions will have a unique solution.
Specifically, the basic "existence and uniqueness theorem" for first order equations, as given in most introductory texts, says
"If f(x, y) is continuous in x and y and "Lipschitz" in y in some neighborhood of [itex](x_0, y_0)[/itex] then the differential equation dy/dx= f(x,y) with initial value [itex]y(x_0)= y_0[/itex] has a unique solution in some neighborhood of [itex]x_0[/itex]".
(A function, f(x), is said to be "Lipschitz" in x on a neighborhood if there exists some constant C so that |f(x)- f(y)|< C|x- y| for all x and y in that neighborhood. One can show that all functions that are differentiable in a given neighborhood are Lipschitz there so many introductory texts use "differentiable" as a sufficient but not necessary condition.)
We can extend that to higher order equations, for example [itex]d^2y/dx^2= f(x, y, dy/dx)[/itex] by letting u= dy/dx and writing the single equation as two first order equations, dy/dx= u and du/dx= f(x, y, u). We can then represent those equations as a single first order vector equation by taking [itex]V= <y, u>[/itex] so that [itex]dV/dx= <dy/dx, du/dx>= <u, f(x,y,u)>[/itex]. Of course, we now need a condition of the form [itex]V(x_0)= <y(x_0), u(x_0)>[itex]is given which means that we must be given values of y and its derivative at the <b>same</b> value of [itex]x_0[/itex], not two different values.<br /> <br /> For example, the very simple equation [itex]d^2y/dx^2+ y= 0[/itex] with the <b>boundary</b> values y(0)= 0, [itex]y'(\pi/2)= 0[/itex] does NOT have a unique solution.<br /> <br /> Again, the basic "existence and uniqueness theorem" for intial value problems does NOT say that there exist a unique solution to a differential equation that will work for any initial conditions. It says that there exists a unique solution that will match <b>specific</b> given initial conditions.[/itex][/itex]
  • · Replies 27 ·
  • · Replies 0 ·
