Can't understand how to compute this limit where x tends to infinity
  • Thread starter Thread starter DanB1993
    Infinity Limit
The problem involves computing a limit as x approaches infinity for the expression (2x^{3} + x)/(3x^{2} − 4x^{3}). This falls under the subject area of calculus, specifically limits and asymptotic behavior.
  • Exploratory, Mathematical reasoning
  • Participants discuss various techniques for evaluating limits at infinity, including dividing by the highest power of x and substituting variables to simplify the expression. Some participants question the rationale behind these methods.
Several participants have provided insights into the methods used to approach the limit, including the technique of simplifying the expression by focusing on the highest power terms. There is an ongoing exploration of different perspectives on the problem, but no explicit consensus has been reached.
Participants note the challenge of dealing with limits at infinity and the common practice of transforming the expression to make it more manageable. There is an implicit understanding of the constraints imposed by the homework context, but specific rules or assumptions are not detailed.
DanB1993
This is a question from a past exam paper:
Compute the limit:
lim x→∞
(2x[itex]^{3}[/itex] + x)[itex]/[/itex](3x[itex]^{2}[/itex] − 4x[itex]^{3}[/itex])
I really had no idea how to approach this but the solution is:
lim x→∞
= lim y→0+
(2 + y[itex]^{2}[/itex])[itex]/[/itex](3y − 4)
2[itex]/[/itex]−4
= −1[itex]/[/itex]2
Hopefully someone can explain to me the method used to obtain this answer.
It's a fairly standard technique- "infinity" is hard to deal with while "0" is very easy- so they have made use of the fact if x goes to infinity, 1/x goes to 0.
Starting from [itex](2x^3+ x)/(3x^2- 4x^3)[/itex], they have divided both numerator and denominator by the highest power of x, [itex]x^3[/itex], to get [itex](2+ 1/x^2)/(3/x- 4)[/itex] and then replaced "1/x" with "y": (2+y^2)/(3y- 4). Then, as x goes to infinity, y goes to 0 so that the limit is just (2+ 0)/(0- 4)= 2/(-4)= -1/2.
Or at infinity you take the highest power in the numerator over the highest power in the denominator. In your case it would be 2x^3/-4x^3 and then x^3 will cancel out leaving you with -2/4 which is -1/2.
Thanks very much for that - very clear.
Thank you
  • · Replies 25 ·
  • · Replies 20 ·
