Rolling Gear and Rack Question
  • Context: Undergrad
  • Thread starter Thread starter Zalajbeg
    Gear Rolling
The discussion revolves around the mechanics of a gear and rack system, specifically focusing on the motion of the gear in relation to the movement of the rack. Participants explore whether the gear will rotate when the rack is pulled and the relationship between the distance moved by the rack and the gear's rotation. The conversation includes theoretical considerations and assumptions about friction, mass distribution, and the design of the gear teeth.
  • Some participants propose that if the rack is pulled a distance 'x', the gear will either move to the right without rotating or will rotate depending on various factors such as friction and the design of the gear teeth.
  • Others argue that the distance traveled by the gear and the number of revolutions are related to the number of teeth on the gear, suggesting a direct correlation between one revolution and a specific horizontal distance.
  • A later reply questions whether the inertia of the gear will affect its horizontal movement apart from the displacement caused by rotation.
  • Some participants suggest that analyzing the system becomes complicated if the gear teeth are not designed properly, as friction could lead to slipping rather than rolling.
  • One participant introduces the idea that the mass distribution of the gear affects its motion, raising questions about how this influences the gear's response to the rack's movement.
  • Another participant poses additional questions about the effects of external forces applied to the gear, questioning how these forces might alter the number of revolutions or cause slipping.
Participants do not reach a consensus on whether the gear will rotate or slide without rotating when the rack is pulled. Multiple competing views remain regarding the influence of friction, mass distribution, and external forces on the gear's motion.
Assumptions about the system include the presence or absence of friction, the mass distribution of the gear, and the design of the gear teeth. These factors introduce uncertainty into the discussion, as different assumptions could lead to varying outcomes.
Zalajbeg
Hi everyone,
http://www.freeimagehosting.net/newuploads/wt15k.jpg
In the picture there is a rack at the bottom and there is a gear above it. The gear is on a axis which can move on a horizontal line and the gear can rotate without friction between the axis and the horizontal housing.
1) If the rack is pulled to the right by a distance of x, will the gear only go to the right without rotation or will it also rotate?
2) If it rotates is there a certain ratio between the distance x and the number of revolutions or does it depend on the velocity of the rack?
assuming the gear and 'line' are not weightless, and there is some friction between the gear teeth, it will turn as does a typical gear. Other assumptions would yield different results.
The distance traveled and the number of revolutions are related via the number of teeth...one revolution = # teeth which = C = 2[pi]r...
one revolution equals C in horizontal distance.
I wonder if the rack will not also carry the gear horizontally with its inertia apart from the displacement because of the rotational motion.
The gear teeth make this more complicated and confusing. It's simpler to get started by assuming there is a wheel that rolls on the "rack" without slipping.
If you draw a free body diagram for the forces on the wheel, then when the rack accelerates it should be obvious the wheel also accelerates.
The center of the wheel will also move, but the amount it moves depends on the mass and the radius of gyration of the wheel. If the mass of the wheel is all at the center or all around the rim, the motion willl be different.
If the gear teeth are cut to a well designed shape (not the triangles you drew) there will be no "friction" between the gears, because the surfaces of the teeth don't "slip" over each other but "roll" over each other just like the wheel rollinig without slipping. If the gear teeth do "slip", and there is friction between them, analyzing what happens in detail would get VERY complicated.
... but the amount it moves depends on the mass and the radius of gyration of the wheel. If the mass of the wheel is all at the center or all around the rim, the motion willl be different.
I fail to see how the mass of the wheel is anyway involved given the initial conditions posed. The rack moves distance 'x'...period.
Then I have two more questions. Let's assume the teeth are well shaped so that they roll over each other. And the rack is pulled with a constant velocity.
1) If a horizontal force is exerted to the top of the gear in the opposite direction of the motion (The force is not strong enough to stop the gear or change the direction of the motion) will the number of revolution be lower? Will the gear have to slip?
2) If the force is in the same direction with the motion will it roll faster than there is no force?
1)suppose there is no friction between the shaft(that is holding gear)and the horizontal line.
rack is pulled to right with a force say "F" which is less then the rotational inertial effects/force of gear and shaft both.
under these assumption the gear will not rotate it will simply slide to the right.
  • · Replies 16 ·
  • · Replies 59 ·
  • · Replies 71 ·
  • · Replies 18 ·
