Reversal of limits of integration in the derivation of probability current density
The discussion revolves around the derivation of the probability current density in quantum mechanics, specifically focusing on the implications of reversing the limits of integration in the context of the continuity equation and the Schrödinger equation. Participants explore the mathematical formulation and the physical significance of the prefactor in the expression for probability current density.
  • Some participants note that changing the limits of integration results in a sign change for the prefactor in the expression for probability current density.
  • Others argue that the prefactor must be negative due to the requirements of the Schrödinger equation and the continuity equation.
  • A participant suggests an alternative derivation of the current's expression, emphasizing the need for local conservation of probability.
  • Some contributions highlight that the sign, along with the imaginary unit, may not have physical significance on its own.
  • A later reply discusses the derivation process involving the time-dependent Schrödinger equation and its implications for the continuity equation.
Participants express differing views on the necessity and significance of the negative prefactor in the probability current density. There is no consensus on whether the sign has physical implications or is merely a mathematical artifact.
The discussion includes various assumptions about the definitions of terms and the context of the equations used, which may not be fully resolved. The relationship between the continuity equation and the probability current density remains a point of contention.
hnicholls
In working out the derivation of the probability current density, I see (based on the definition of j(x,t)) that the limits of integration are changed from
d/dt∫(b to a) P(x.t) dx = iħ/2m[ψ*(x.t)∂/∂xψ(x.t) - ψ(x.t)∂/∂xψ*(x.t)](b to a)
to
d/dt∫(b to a) P(x.t) dx = -iħ/2m[ψ*(x.t)∂/∂xψ(x.t) - ψ(x.t)∂/∂xψ*(x.t)](a to b)
Thus, the prefactor becomes -iħ/2m as a result of reversing the limits of integration.
Is there a reason that the prefactor must be in terms of -i?
Thanks
The changed limits just changed the sign from + to -, the ##\frac{i\hbar}{2m}##-part is quantum mechanics.
I understand that the sign change is a result of reversing the limits and that the iħ/2m part is what quantizes the result, my question is why does the result need to me negative, rather than positive.
Thanks again.
Let me give you an alternative way to derive the current's expression, which maybe has more sense. What we are looking for is a function that satisfies the “continuity equation”:
[tex]{{\partial }_{t}}\rho +{{\partial }_{x}}j=0[/tex]
which comes from the requirement of local conservation of probability. In the above equation [itex]\rho ={{\Psi }^{*}}\Psi[/itex] is the probability density, so when you calculate [itex]{\partial \rho }/{\partial t}\;[/itex] using S.E. and its complex conjugate, you find:
[tex]{{\partial }_{t}}\rho =-\frac{i\hbar }{2m}{{\partial }_{x}}\left( \Psi {{\partial }_{x}}{{\Psi }^{*}}-{{\Psi }^{*}}{{\partial }_{x}}\Psi \right)[/tex]
So, when you compare this with the continuity equation, you have to set:
[tex]j=\frac{i\hbar }{2m}\left( \Psi {{\partial }_{x}}{{\Psi }^{*}}-{{\Psi }^{*}}{{\partial }_{x}}\Psi \right)[/tex]
A minus sign does not mean that the result is negative, the integral itself can be negative as well. I don't know the context of that equation, but I think it is just a complex phase anyway. In other words, the sign (together with i) has no physical significance on its own.
But isn't j (x,t) defined as,
[tex]j=\frac{-i\hbar }{2m}\left( \Psi {{\partial }_{x}}{{\Psi }^{*}}-{{\Psi }^{*}}{{\partial }_{x}}\Psi \right)[/tex]
The sign is uniquely defined by the Schrödinger equation, which reads (setting [itex]\hbar=1[/itex])
[tex]\mathrm{i} \partial_t \psi(t,x)=-\frac{\Delta}{2m} \psi(t,x)+ V(x) \psi(t,x).[/tex]
Multiplying with [itex]\psi^*[/itex] leads to
[tex]\psi^*(t,x) \mathrm{i} \partial_t \psi(t,x)=\psi^*(t,x) \left [-\frac{\Delta}{2m} \psi(t,x)+ V(x) \psi(t,x) \right].[/tex]
Then subtracting the conjugate complex of this equation and multiplying with (-i) leads to
[tex]\partial_t |\psi(t,x)|^2=\vec{\nabla} \cdot \frac{\mathrm{i}}{2m} [\psi^*(t,x) \vec{\nabla} \psi(t,x)-\psi(t,x) \vec{\nabla} \psi^*(t,x)].[/tex]
Comparing this with the continuity equation leads to
[tex]\rho(t,x)=|\psi(t,x)|^2, \quad \vec{j}=-\frac{\mathrm{i}}{2m} [\psi^*(t,x) \vec{\nabla} \psi(t,x)-\psi(t,x) \vec{\nabla} \psi^*(t,x)],[/tex]
as already given by cosmic dust.
So, proceeding with the assumption that ψ(t,x) satisfies the TDSE,
(−ℏ2/2m)∂x2ψ(t,x) = (iℏ)∂tψ(t,x)
with V(x)ψ(t,x) = 0
Dividing by iℏ
(−ℏ/2mi)∂x2ψ(t,x) = ∂tψ(t,x)
Multiply by -i
(−iℏ/2m)∂x2ψ(t,x) = ∂tψ(t,x)
Multiplying by ψ(t,x)∗
(−iℏ/2m)∂x2ψ(t,x)∗ψ(t,x) = ∂tψ(t,x)ψ(t,x)∗
P(t,x) = ψ(t,x)ψ(t,x)∗
So, (−iℏ/2m)∂x2ψ(t,x)∗ψ(t,x) = ∂tP(t,x)
and the left side of this equation can be rewritten as
(−iℏ/2m)∂x[ψ(t,x)∗∂xψ(t,x) - ψ(t,x)∂xψ(t,x)∗]
but, this is ∂xj(t,x) where j(t,x) is defined as
(−iℏ/2m)[ψ(t,x)∗∂xψ(t,x) - ψ(t,x)∂xψ(t,x)∗]
and ∂xj(t,x) = ∂tP(t,x) because the "continuity equation" requires that
∂xj(t,x) - ∂tP(t,x) = 0
So, the reversal of the limits of integration is necessary so that the TDSE and the "continuity equation" are both satisfied.
That seems right.
  • · Replies 19 ·
  • · Replies 18 ·
