Tennis Ball Launcher Calcuations
The discussion revolves around the calculations needed for building a tennis ball launcher. The original poster outlines the parameters they have, including an angle, a spring constant, and a horizontal distance the ball should travel. They express uncertainty about calculating the necessary launch velocity and the stretch distance of the string, noting the absence of certain variables like maximum height and time.
  • Participants discuss using equations of motion to determine flight time and launch velocity, rather than relying solely on energy equations. There are questions about how to relate the vertical and horizontal components of motion and the implications of neglecting air resistance.
Some participants have offered guidance on focusing first on calculating the launch velocity and suggested re-evaluating the energy equations by redefining the height reference. There is ongoing exploration of how to approach the problem, with multiple interpretations of the necessary calculations being discussed.
Participants note the lack of certain variables and the requirement to calculate before simulating the launcher. The original poster has confirmed they are neglecting air resistance, which is relevant to the projectile motion calculations.
Redfire66
I'm building a tennis ball launcher (as most people did) and I barely have some calculations done. I already have a measurement for my project (i.e. an angle and such), a k value for my string and a distance that it should travel horizontally. Theoretically, I'm supposed to calculate the velocity it takes the ball to travel the distance horizontally and a stretch distance (x) for my string; I'm not given a maximum height (but it should be above 1m), or time but I do have an initial height where the ball is launched (which is the height of my launcher) - there's quite a bit of missing variables without actually simulating it (since it's required that I calculate before I simulate)
Dx=vtcosθ
Fg=kx
E=E
Dy=vtsinθ
V=vcosθ or sinθ depending on direction
(I might be missing some but I suppose you'd get the idea)
Determined the k value by determining the force (mg) and relating to the F=kx equation
I've tried to do Et=Et
But I end up getting stuck with
E(at launch) = E (when pulled back)
mgh + 1/2mv^2 = 1/2kx^2 + mgh
since the heights are different, and since I don't know how far back I stretch it (x), then I won't be able to determine how high it is (for the mgh on the second half); maybe I did it wrong or used the wrong method, but that's how I seem to think I should do it
I'm still thinking it through how I'm supposed to attempt this, and seems sort of difficult without being given more variables
You don't need energy equations for that. I would use equations of motion. Start by working out the flight time using the vertical velocity and the equations of motion.
Dx=vtcosθ
Fg=kx
E=E
Dy=vtsinθ
Welcome to the PF.
If you check out the bottom of this page, you will see some other "tennis ball launcher" threads that may also help you out.
BTW, air resistance is not negligible for a tennis ball. Have you been told to ignore it anyway for this project? If not, there are some reasonable info pages on factoring air resistance into projectile calcs at wikipedia.org :smile:
Well other than the fact that I need to calculate velocity, I'm not sure of any other method to calculate the stretch distance for string (x). Maybe I forgot an equation?
Welcome to the PF.
Yes, I am neglecting air resistance. Sorry for not mentioning; am most of the other projects that I am aware of don't have some of the information I'm looking for.
One step at a time. Have you already calculated the launch velocity required?
Then regarding...
I would redefine the origin as the height when pulled back so it becomes..
mgh + 1/2mv^2 = 1/2kx^2 + 0
Then presumably the elastic is pulled back at the launch angle so
h = xsinθ
Then regarding...
h = xsinθ
Actually no, I have no calculated the initial velocity, which is why I sort of went to check how I would approach the others. I guess it just adds to my confusion if I couldn't get velocity or time
Also, when pulled back, wouldn't there still be a height since I don't know if I'm pulling back the elastic all the way to the ground (to make height zero)
Ok so you know that (ignoring air resistance) you get max distance when the launch angle is 45 degrees. If you use that as the launch angle and you know the distance required you can work out the launch velocity required.
Concentrate on the launch velocity first but..
Yes there would but what really matters in your equation is the difference between h at launch and h when armed (pulled back). Perhaps it would have been better had I rearranged your equation like this...
mg(hlaunch - hpulled back) + 1/2mv2 = 1/2kx2
or
mgΔh + 1/2mv2 = 1/2kx2
where
Δh = xsinθ
or
where
Δh = xsinθ
Oh I see... sort of. Also, for determine the velocity first (sorry for jumping around), how should I approach this? Would it be possible to relate the mass of the projectile and vertical plane into the horizontal? It doesn't really seem like I should do it since they are perpendicular, but I don't have any other idea since they are related in time and velocity
I already attempted with splitting up the horizontal and vertical planes, and I have a feeling that I should begin with the vertical for to solve for time, but I get stumped which formula to use or how to approach this since I don't want to neglect the ball's mass and initial height.
Oh I see... sort of. Also, for determine the velocity first (sorry for jumping around), how should I approach this? Would it be possible to relate the mass of the projectile and vertical plane into the horizontal? It doesn't really seem like I should do it since they are perpendicular, but I don't have any other idea since they are related in time and velocity..
That's exactly the right approach..
I would assume a 45 degree launch angle initially then..
Using standard equations of motion write an equation for the vertical motion in terms of:
Initial vertical velocity
Acceleration
flight time
Write an equation for the horizontal motion in terms of:
Horizontal velocity
Distance
flight time
How many unknows are there? How many equations do you have?
Acceleration
flight time
Horizontal velocity
Distance
flight time
How many unknowns are there? How many equations do you have?
I have a few equations and not a lot of unknowns; I think that if I were to write a horizontal equation and vertical equation, I would be able to relate the two together to determine time to start it off, by eliminating velocity in the equation
basically dx = vt
but since I'm in the horizontal plane I could re-write it as
dx/vcosθ = t
And if I applied it to the vertical equation
-dy = vtsinθ - 1/2gt^2
Where dy is the height of my launcher
But how would I determine the height that it reaches over the net?
That is, there is a specific distance that it must travel... so should I use the velocity to determine how long it would take to reach a specific distance to determine if it goes above the net? (even though I'm pretty sure it would either way)
  • · Replies 39 ·
  • · Replies 16 ·
10K
